psjoe 1 #1 Posted August 28, 2009 Well I tried searching for for it and I can not find it so it must be called something else. Does anyone know the name for the strut that holds the seat up on a 312-8 so you can fill the gas tank? Thanks -Joe Share this post Link to post Share on other sites
nylyon-(Admin) 8,575 #2 Posted August 28, 2009 The easiest way to find this out is to check the links section for parts suppliers or for the Toro parts, go to the site, look up your model and check the parts diagram. For my 416 it is called: Toro Consumer 114343 Spring-Gas My 414 doesn't have that part. Share this post Link to post Share on other sites
psjoe 1 #3 Posted August 28, 2009 Coach- Got it. Looks like the same part. 114343 GAS SPRING Thanks Share this post Link to post Share on other sites
damitray 0 #4 Posted September 1, 2009 I don't know if you want OEM or not but wheelhorse is expensive...I took it off and took it to Auto Zone for a close usable match. Share this post Link to post Share on other sites
truckin88 104 #5 Posted September 2, 2009 I have done the toro route it is about $35. I just did the AZ route, and got one with some more umph...it was $23, but the holes had to be bored out with the dremel, works well so far though Share this post Link to post Share on other sites
