tntatro 171 #1 Posted April 27 Hello, I recently bought a Wheel Horse 656 and would like to rebuild the engine but I can't find parts for it. The bore is 009 over and the crankpin is really worn also so it needs 010 over on the bore, maybe 020 and 010 under on the crankpin. The valves don't look bad. Anyone know a source for good used parts or new old stock? So far I know I need a good crankshaft or 010 rod and a 010 or 020 piston and rings. I think the crankshaft part number is 31791 based on an IPL in the manuals section. The .010 piston is 31798B. I might have found a 020 piston but I'm not going to buy anything unless I can get the crankshaft fixed or replaced. I don't know what a .010 rod would be. Thanks, Tim Share this post Link to post Share on other sites
ebinmaine 63,565 #2 Posted April 27 @76c12091520h K & B Horse Parts may have ideas Share this post Link to post Share on other sites
c-series don 7,923 #3 Posted April 27 I may have a piston and rod. Since you provided part numbers that will make it easy for me to check as my stuff is new in box. I honestly think it’s mine is for a 3hp but I will check. If I have it I’ll PM you. 1 Share this post Link to post Share on other sites
tntatro 171 #4 Posted April 27 1 hour ago, ebinmaine said: @76c12091520h K & B Horse Parts may have ideas Thanks, I just sent them a message requesting parts. 1 Share this post Link to post Share on other sites
tntatro 171 #5 Posted April 27 1 hour ago, c-series don said: I may have a piston and rod Thanks, let me know if you come up with anything. I'm mostly concerned with the crankshaft though. I need to get that before I dare go buying other parts. 1 Share this post Link to post Share on other sites
ebinmaine 63,565 #6 Posted April 27 Just now, tntatro said: Thanks, let me know if you come up with anything. I'm mostly concerned with the crankshaft though. I need to get that before I dare go buying other parts. I've gotten a good used HH60 crankshaft from Lincoln at A to Z. Share this post Link to post Share on other sites
tntatro 171 #7 Posted April 27 1 minute ago, ebinmaine said: I've gotten a good used HH60 crankshaft from Lincoln at A to Z. Okay, I'll try them also. Thanks 1 Share this post Link to post Share on other sites
