Coors 0 #1 Posted August 28, 2009 I just picked up a wheel horse snow plow (blade) it has the ID # of 06-48BC01 (39366). I have a 1995 520H Wheel Horse with swept front axles. I am trying to figure out exactly what I need to make this work. I looked at the sticky thread with the snow plow info and I saw what a snow plow (06-48BC02). What is different between the 06-48BC01 and the 06-48BC02????? And is there a difference between 06-48BC01 and 79350 or 79364? Some sites say I need a completing package "81640 - 48" Snow Blade Completing Package for $ 289.80" and I also found I just need 105-1501 package make it work. I thought I knew what I needed now I am more confused :scratchead: Share this post Link to post Share on other sites
whfan74 2,074 #2 Posted August 28, 2009 There was just a recent thread on this in the last couple of days. Take a look a little bit farther down the list concerning 520's and attachments. That should get you pointed in the right direction. Share this post Link to post Share on other sites
Coors 0 #3 Posted August 28, 2009 There was just a recent thread on this in the last couple of days. Take a look a little bit farther down the list concerning 520's and attachments. That should get you pointed in the right direction. That was my post earlier. I was just wondering what the differnence between the 06-48BC01 and the 06-48BC02 blade. The instructions on the sticky thread is for the 02, Thanks Share this post Link to post Share on other sites
C-Series14 15 #4 Posted August 28, 2009 Have you tried going to Toro's site and looking at the 2 blades? The 06-48bc01 is a 1984-1989 48" blade and the 06-48bc02 is a 1990 blade. 79350 is listed for the 300 Series as well as the 79364. All these blades will work on the 520 with the extension, I believe... The 520 with the fwd swept axle needs the extension for the blade to make it longer, it mounts on the rear of the blade's frame which bolts into the rear axle mount. That is about all I know about the new stuff! Maybe one of the MANY 520 owners will help out... Share this post Link to post Share on other sites
Coors 0 #5 Posted August 29, 2009 Have you tried going to Toro's site and looking at the 2 blades? The 06-48bc01 is a 1984-1989 48" blade and the 06-48bc02 is a 1990 blade. 79350 is listed for the 300 Series as well as the 79364. All these blades will work on the 520 with the extension, I believe... The 520 with the fwd swept axle needs the extension for the blade to make it longer, it mounts on the rear of the blade's frame which bolts into the rear axle mount. That is about all I know about the new stuff! Maybe one of the MANY 520 owners will help out... I was just wanting a little more info about the snow plow long and short sticky thread. It gave a pretty good description of the '02 plow, and I was wondering what (if anything extra) '01 plow was different. It also stated that the hitches listed did not apply for the 520H with front swept axles. I am hoping to take the info from this site and make my own picture instructions at the end for the site. Thanks for the help Share this post Link to post Share on other sites
mcwh1950 2 #6 Posted August 30, 2009 Some sites say I need a completing package "81640 - 48" Snow Blade Completing Package for $ 289.80" and I also found I just need 105-1501 package make it work. coors the 105-1501 package is owning a lift handle and cable Share this post Link to post Share on other sites
