Brian Taylor 4 #1 Posted April 23, 2024 (edited) I have a Wheel horse 314-8 73403 that will not start. It was running fine when I parked it last fall. When I try and start it no reaction except the PTO light comes on on the light bank on the left of the dash. The oil light flashes but I think that should flash when there is no oil pressure. I checked the PTO and it is spinning OK with the brake on. Any help would be appreciated. Edited April 23, 2024 by Brian Taylor Share this post Link to post Share on other sites
Ed Kennell 46,795 #2 Posted April 23, 2024 Is the PTO disengaged and making contact with the two PTO safety switches? Are all the wires connected to the two switches? Are the fuses OK? 2 Share this post Link to post Share on other sites
Blasterdad 3,167 #3 Posted April 23, 2024 Did you check the battery & connections? Were you sitting on the seat with the clutch pushed in? Any of those could make it not crank over... 1 Share this post Link to post Share on other sites
Blasterdad 3,167 #4 Posted April 23, 2024 Oh yeah, to 1 Share this post Link to post Share on other sites
Brian Taylor 4 #5 Posted April 23, 2024 Fuses are good, I don't know how to check the contact with the PTO and the safety switches. Share this post Link to post Share on other sites
Brian Taylor 4 #6 Posted April 23, 2024 16 minutes ago, Blasterdad said: Did you check the battery & connections? Were you sitting on the seat with the clutch pushed in? Any of those could make it not crank over... I just cleaned the battery terminals and I was sitting on the seat when I was trying to start it. Share this post Link to post Share on other sites
953 nut 68,155 #7 Posted April 23, 2024 Please give us a bit more information. Have you taken your battery to an auto parts store to have it load tested? When you turn the key to the START position what happens? Have you removed the old gas and replaced it with new gas? If the engine does turn over is fuel being sent to the carburetor by the fuel pump? Attached is a wiring system diagram that may be helpful. Share this post Link to post Share on other sites
Brian Taylor 4 #8 Posted April 23, 2024 The only reaction is the two dash lights come on, PTO and oil pressure. It will not turn over. The battery is fully charged. Share this post Link to post Share on other sites
Blasterdad 3,167 #9 Posted April 23, 2024 Do you have a multimeter & a test light? If so check the battery voltage, then see if you're getting voltage to the solenoid with the test light when you turn the key to the "start" position. If not, try jumping the solenoid... Share this post Link to post Share on other sites
Brian Taylor 4 #10 Posted April 23, 2024 Battery reads 12.9 volts and at the solenoid on the nuts it also reads 12.9 volts in "start" Share this post Link to post Share on other sites
Blasterdad 3,167 #11 Posted April 23, 2024 Do you mean the big nuts? If so you may have a bad starter. Can you hear the solenoid click? Share this post Link to post Share on other sites
Brian Taylor 4 #12 Posted April 23, 2024 No the solenoid does not click. Share this post Link to post Share on other sites
Blasterdad 3,167 #13 Posted April 23, 2024 Are you getting voltage to the little terminal on the solenoid in "start"? Share this post Link to post Share on other sites
Brian Taylor 4 #14 Posted April 23, 2024 There are two wires below the solenoid which should I check or just check across them?? Share this post Link to post Share on other sites
953 nut 68,155 #15 Posted April 23, 2024 1 minute ago, Brian Taylor said: There are two wires below the solenoid which should I check or just check across them?? One of the small wires goes to ground and the other one (probably blue) should read battery voltage when the key is in START. 1 Share this post Link to post Share on other sites
Blasterdad 3,167 #16 Posted April 23, 2024 5 minutes ago, Brian Taylor said: There are two wires below the solenoid which should I check or just check across them?? According to the wiring diagram it should be the purple wire. Share this post Link to post Share on other sites
Brian Taylor 4 #17 Posted April 23, 2024 12.9 volts to the left wire while disconnected 8.7 volts to the right wire while disconnected. Share this post Link to post Share on other sites
Brian Taylor 4 #18 Posted April 23, 2024 I was reading the wires not the terminals. The S wire read 12.9 volts while disconnected and the switch turned to start. Share this post Link to post Share on other sites
Blasterdad 3,167 #19 Posted April 23, 2024 According to the diagram it has a neutral 2 minutes ago, Brian Taylor said: 12.9 volts to the left wire while disconnected 8.7 volts to the right wire while disconnected. We need the color of the wire, not left or right. The purple wire should be getting 12 volts. The black wire should be a ground. According to the diagram your tractor has a neutral switch, oil switch, PTO switch, & seat switch. Did you check the oil? Try runninng a jumper wire from the positive terminal of the battery to the purple terminal of the solenoid with the tractor in neutral & the purple wire not hooked up to the solenoid. Share this post Link to post Share on other sites
953 nut 68,155 #20 Posted April 23, 2024 (edited) Be sure the transmission is out of gear. Take a small jumper wire from the battery "+" terminal and touch it to the solenoid small terminal.where the wire from the ignition switch "S" was connected @Blasterdad posted while I was typing. Edited April 23, 2024 by 953 nut Share this post Link to post Share on other sites
Brian Taylor 4 #21 Posted April 23, 2024 I did check the oil and the oil is right at the mark not below where it needs oil added. I need to buy some oil to fill it. Share this post Link to post Share on other sites
Brian Taylor 4 #22 Posted April 23, 2024 I don't have a jump wire set up check it that way. Share this post Link to post Share on other sites
Blasterdad 3,167 #23 Posted April 23, 2024 2 minutes ago, 953 nut said: Be sure the transmission is out of gear. Take a small jumper wire from the battery "+" terminal and touch it to the solenoid small terminal.where the wire from the ignition switch "S" was connected @Blasterdad posted while I was typing. We both said the pretty much the same thing. 1 Share this post Link to post Share on other sites
Brian Taylor 4 #24 Posted April 24, 2024 (edited) Transmission has been out of gear all long, I checked with the wire like you said and the solenoid engaged the starter. Edited April 24, 2024 by Brian Taylor Share this post Link to post Share on other sites
Blasterdad 3,167 #25 Posted April 24, 2024 1 hour ago, Brian Taylor said: Transmission has been out of gear all long, I checked with the wire like you said and the solenoid engaged the starter. Ok great, now we know one or more of you safety switches is interrupting the start circuit, I'd try filling it with oil first. That would explain the oil light flickering too. 1 Share this post Link to post Share on other sites
