Vintage_Wheel_Horse_Lover 10 #1 Posted April 23 (edited) hello all I have a 312-8 and I was mowing a ladies yard from our church with it and the mule drive started locking up and screaming. turns out it was the inner pulley[furthest away from the nit that holds them and the cover on.the bearing was red hot and starting to seize. it freed up after cooling. but now my issue is is that I cant find a pulley that fits the shaft I can find the right pulley size. but the bearings inside diameter is off. where can I get this. because I checked tractor supply, napa, and the lawnmower place near me and no one can get it. Edited April 23 by Vintage_Wheel_Horse_Lover Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,617 #2 Posted April 23 Is it a flat pulley or a V-pulley? Some decks use one of each and others use two the same with a 6-sided belt. 1 Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 10 #3 Posted April 23 one is wider and one is narower i beleive it is flat Share this post Link to post Share on other sites
Achto 26,796 #4 Posted April 23 1 hour ago, Vintage_Wheel_Horse_Lover said: but now my issue is is that I cant find a pulley that fits the shaft I can find the right pulley size Can you change the bearing in your existing pulley? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,617 #5 Posted April 23 That idler assembly is part of the mower deck so here is an illustrated parts list of the flat and V-belt idler. https://www.partstree.com/models/05-42ms05-toro-42-side-discharge-mower-deck-1986/rear-discharge-mower-42-in-107-cm-vehicle-identification-number-05-42mr04-5/ Have a local Toro dealer? If I remember correctly one of the pulleys are available from alternate sources like Stens or Rotary. Also notice the spacers are different lengths. 1 Share this post Link to post Share on other sites
Ed Kennell 36,234 #6 Posted April 23 I may have one. I'll check my buckets of pulleys and get back to you. Share this post Link to post Share on other sites
Wayne0 311 #7 Posted April 24 On 4/23/2024 at 11:04 AM, Vintage_Wheel_Horse_Lover said: one is wider and one is narower i beleive it is flat Fleabay and the jungle have the pulley you need. Share this post Link to post Share on other sites
Ed Kennell 36,234 #8 Posted April 24 I do not have one Share this post Link to post Share on other sites
