Fordiesel69 271 #1 Posted April 23, 2024 Was wondering is there supposed to be 2 rod supports? Also belt routing. There are 2 grooves in the pto pulley. Photos on next post as I have to reduce the size. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #2 Posted April 23, 2024 Not sure if you are talking tractor or mower Share this post Link to post Share on other sites
Fordiesel69 271 #3 Posted April 23, 2024 need belt diagram to install new belt onto the pto pulley and then onto the 42" SD deck. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #4 Posted April 23, 2024 Share this post Link to post Share on other sites
Fordiesel69 271 #5 Posted April 24, 2024 Thank you for that. The manual helped a ton. Unless im imagining things the 200 series decks I swear turn double the RPM as the 300/400/500 classics. Grass shoots twice as far and not only that the heavy grass really lugged that 14HP command down hard. Share this post Link to post Share on other sites
