sodbuster
deck rotation
sodbuster
I got my deck on my 502.blades are turning wrong direction to cut.is there a counterclockwise blade available? my engine turn counterclockwise.there isnt enough room to twist the belt.thanks
htopjimmy26
Umm, I don't know anything about the real old stuff but try this, can you flip the blades over? Good luck :thumbs2:
sodbuster
:thumbs2: didnt think of that l will pull the deck and see if I can.
tarcoleo
sodbuster,
Flipping the blade over, with the rotation in the wrong direction, will present the
sharp edge first, but blow the grass down, not suck it up. Its like putting
a propeller on an airplane backwards and reversing the engine. That would
be great for flying backwards. Mmmmmm.
swamp yankee :thumbs2:
Nick
If your talking a 502 with gear driven deck the blades will turn in opposite direction so they have to be on the proper side to cut. There is a left and a right.
