23 Reo 221 #1 Posted April 17 I'm having a heck of a time getting my fan screen bolts out. I've been spraying with Kroil and also shocking the screws with a #3 phillips and a large hammer. This method has worked in the past but no luck this time. Share this post Link to post Share on other sites
Pullstart 59,813 #2 Posted April 18 Depending on your screwdriver handle, it may just fit a box end wrench. Hang one on there and keep tapping. Maybe a little pressure down on the wrench. Pipe wrench, big crescent, etc… 1 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 114 #3 Posted April 18 I use a impact driver. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 63,262 #4 Posted April 18 Manual Impact Driver. Amazing how well they work. I got one several years ago because it was recommended by several people on this site. Definitely one of my better investments. 4 1 Share this post Link to post Share on other sites
ebinmaine 63,262 #5 Posted April 18 Oh and ... TIGHTEN it first!! Then loosen just ONE click. Repeat. Repeat. Repeat. 1 1 1 Share this post Link to post Share on other sites
kpinnc 10,819 #6 Posted April 18 And square bits grip better than phillips. Just be aware if it strips with a square bit, it's not coming out... 1 Share this post Link to post Share on other sites
Blasterdad 2,564 #7 Posted April 18 36 minutes ago, 23 Reo said: I'm having a heck of a time getting my fan screen bolts out. I've been spraying with Kroil and also shocking the screws with a #3 phillips and a large hammer. This method has worked in the past but no luck this time. All are great proven methods, just be careful hitting the flywheel too hard, it can break and/or dislodge the magnets. If one of the screws does strip out I've cut a slot in them before with an angle grinder & used a big flat screwdriver. If that fails I resort to welding a small nut on it. 3 1 Share this post Link to post Share on other sites
oliver2-44 8,869 #8 Posted April 18 48 minutes ago, ebinmaine said: Manual Impact Driver. Amazing how well they work. I got one several years ago because it was recommended by several people on this site. Definitely one of my better investments. 1 Share this post Link to post Share on other sites
WHX?? 46,835 #9 Posted April 18 1 hour ago, Blasterdad said: resort to welding a small nut on it. The heat may help loosen. I have twisted the heads off tho. 1 1 Share this post Link to post Share on other sites
87 416-8 horse 208 #10 Posted April 18 I’ve had luck with heating them up and instantly spraying penetrating oil on them. And then hit them with a manual impact like EB said. IMG_2268.webp 2 1 Share this post Link to post Share on other sites
Ed Kennell 35,902 #11 Posted April 18 2 hours ago, Blasterdad said: . If one of the screws does strip out I've cut a slot in them before with an angle grinder & used a big flat screwdriver. I've taken many out by grinding a slot. Not sure, but the heat and vibration from the grinding may also help. 1 1 1 Share this post Link to post Share on other sites
953 nut 51,858 #12 Posted April 18 The phillips head makes a rather good centering device to drill out the old bolt with a 13/64" bit and re-tap the 1/4-20 threads. Once you snap off the head it is much more difficult to center the bit. 5 1 Share this post Link to post Share on other sites
WHX?? 46,835 #13 Posted April 18 1 hour ago, 953 nut said: snap off the head it is much more difficult to center the bit. Ask me how I know... 3 1 Share this post Link to post Share on other sites
Pullstart 59,813 #14 Posted April 18 10 hours ago, 87 416-8 horse said: I’ve had luck with heating them up and instantly spraying penetrating oil on them. And then hit them with a manual impact like EB said. IMG_2268.webp 6.79 kB · 0 downloads I have an old chunk of paraffin wax sitting in my torch tray. That heat pulls in the wax and lubes the threads well. 1 1 1 Share this post Link to post Share on other sites
peter lena 8,081 #15 Posted April 18 @23 Reo https://www.ottofrei.com/products/irwin-4-mini-locking-vise-grips use this , or similar , with side jaw grip, for best bite , then tapping the back side of the plyer with light hammer , solid grip / no play / bounce should do it . picture of grip is only a reference to plyer size / type , the more solid your grip , the more impact effect it will have . pipefitter approved , pete 1 1 Share this post Link to post Share on other sites
ranger 1,651 #16 Posted April 18 If you don’t have an impact driver, you could try a cordless drill driver. Set on slow speed, screwdriver mode. Run in reverse with the clutch adjusted at a low setting,, plenty of pressure, and see if the shocking loosens it. You can up the clutch setting as long as the bit doesn’t slip in the screw head. You never know, it might work! 1 Share this post Link to post Share on other sites
Gasaholic 183 #17 Posted April 21 One I don't see mentioned but have used in the past especially on those where the screwdriver slot stripped out - sharpen up a small cold chisel and use that to work around the edges/sides of the screw - often was enough to pop them loose so they'd unthread by hand... and those that were more stubborn, works to shave "flats" on either side of the screw where you can then grip it with vise-grips. It does take a little bit of a "feel" for the right angle and right amount of hammering to shock them loose without breaking a fin (Which I have never done) - I tended to aim the chisel along the length of the fin (parallel to the fin instead of perpendicular across) - with a good sharp cold chisel (the screws aren't hardened steel - relatively soft metal) it doesn't take long - after they are out they get replaced (if the cross slots are cammed out) or cleaned up at the grinder and then cut slots across (or grind square flats on the sides for an open end wrench to grip) 1 Share this post Link to post Share on other sites
