Ex wh1257 61 #1 Posted April 16, 2024 Hello everyone, I just had a question about a Kohler KT 17 engine. I would like to convert it to a KT 19 engine. Now my question is whether the crankshaft is the same thickness. I already know that the bore is the same and I found out that the connecting rod a 19 hp engine is shorter than a 17 hp engine, this is the only difference, wondering if anyone can help me with the correct information Share this post Link to post Share on other sites
Ed Kennell 44,093 #2 Posted April 16, 2024 I don't have an answer to your crankshaft question, but I am curious as to what else is different between the 17 and 19 HP engines to create the additional 2 HP? Share this post Link to post Share on other sites
953 nut 63,556 #3 Posted April 16, 2024 5 hours ago, Ex wh1257 said: connecting rod a 19 hp engine is shorter than a 17 hp engine The connecting rods is shorter on the 19 HP because the throw of the crank is longer resulting in 6.7 : 1 compression ratio as compared to the 17 HP having 6.0 : 1 compression. Crank and rods are the only difference. 1 2 Share this post Link to post Share on other sites
Ed Kennell 44,093 #4 Posted April 16, 2024 2 minutes ago, 953 nut said: throw of the crank is longer Thanks Richard. So the block and head are the same. 1 Share this post Link to post Share on other sites
953 nut 63,556 #5 Posted April 16, 2024 18 minutes ago, Ed Kennell said: Thanks Richard. So the block and head are the same. Everything on the K Twins is interchangeable except the crank and rods. I just looked it up, the crank throw on the KT- 17 is 2.75 and on the 19 it is 3.062. The magnum twins run a bit lower compression ratio and the heads have a different part number which probably is the reason for the lower compression. 1 Share this post Link to post Share on other sites
Ex wh1257 61 #6 Posted April 17, 2024 6 hours ago, 953 nut said: Everything on the K Twins is interchangeable except the crank and rods. I just looked it up, the crank throw on the KT- 17 is 2.75 and on the 19 it is 3.062. The magnum twins run a bit lower compression ratio and the heads have a different part number which probably is the reason for the lower compression. so the conclusion if I want to change it I need a different crankshaft and different connecting rods, the connecting rods alone are unfortunately not enough 1 Share this post Link to post Share on other sites
Ed Kennell 44,093 #7 Posted April 17, 2024 (edited) 4 hours ago, Ex wh1257 said: so the conclusion if I want to change it I need a different crankshaft and different connecting rods, the connecting rods alone are unfortunately not enough Yes, I was sure only changing to a shorter rod would actually decrease the compression and the HP. Richard had the answer that the larger throw of the KT19 crankshaft is what increases the stroke, the compression and the HP. Edited April 17, 2024 by Ed Kennell 1 Share this post Link to post Share on other sites
