Mike'sHorseBarn 3,585 #26 Posted May 3, 2024 2 hours ago, WHX?? said: Not really... the PO got it for free from his dad's estate and neglected it. His dad must have taken good care of it. I'm just thankful the nut must've not had it long or didn't use it much....one or the other because other than what you fixed, it is in pretty good shape. If got rid of that wonky bracket on the clutch pedal and properly adjusted it so the pedal sits where it needs to and the brake works as it should. The brake shaft is leaking fluid so I'll address that seal too. I just can't figure out the front tie rods. They are both too short and the front wheels toe out. Gonna have to put on a new set because that bugs the crap out of me! 1 Share this post Link to post Share on other sites
peter lena 9,936 #27 Posted May 3, 2024 @ MIKE,S HORSEBARN , https://www.google.com/search?q=sway+bar+end+link+bushings&rlz=1C1CHBF_enUS866US866&oq=sway+bar+end+&gs_lcrp=EgZjaHJvbWUqBwgDEAAYgAQyBwNKgCALACAQ&sourceid=chrome&ie=UTF- , sway bar end link bushings , make a good bolt on gain . regularly never look for a specific item , just a related site , gives you more ideas / options , don't tell anyone I told you that , I get , you can't do that , for an idea change . over the fence , pete Share this post Link to post Share on other sites
WHX?? 57,278 #28 Posted May 3, 2024 (edited) 1 hour ago, Mike'sHorseBarn said: the nut must've not had it long or didn't use it much... Two years is all he had it. 1 hour ago, Mike'sHorseBarn said: the front wheels toe out. I noticed that too... didn’t bother me too much as a few of my fixed tie rod tractors have it too. Bent spindles ?? Edited May 3, 2024 by WHX?? 2 Share this post Link to post Share on other sites
