rmaynard 17,433 #1 Posted April 9, 2024 What is the normal amount that the throttle cable should come out from idle to full throttle on a typical tractor such as an 857, or 875? My 875 that I just replaced the cable on only moves about 1/2" from idle to full throttle. Seems to me that the old cable (when working) moved quite a bit more. Share this post Link to post Share on other sites
Achto 32,106 #2 Posted April 9, 2024 (edited) 11 minutes ago, rmaynard said: What is the normal amount that the throttle cable should come out from idle to full throttle Does your cable hook directly to the throttle wheel or does it hook to an arm sticking off from the wheel? I had one small block that the cable hooked into the wheel, it had a real short movement on the cable. I actually welded an arm on to the wheel to get more throttle cable movement. Edited April 9, 2024 by Achto 2 Share this post Link to post Share on other sites
rmaynard 17,433 #3 Posted April 10, 2024 It's just a wheel, no arm. I'm thinking most of my others have the arm. I don't weld. Guess I'll have to find one with an arm. 1 Share this post Link to post Share on other sites
wallfish 20,226 #4 Posted April 10, 2024 24 minutes ago, rmaynard said: It's just a wheel, no arm. I'm thinking most of my others have the arm. I don't weld. Guess I'll have to find one with an arm. Let me know Bob, I have one. I'll just trade you for yours and weld one on it later to put back on the engine. I can mail it or bring it to the show 1 Share this post Link to post Share on other sites
rmaynard 17,433 #5 Posted April 10, 2024 9 minutes ago, wallfish said: Let me know Bob, I have one. I'll just trade you for yours and weld one on it later to put back on the engine. I can mail it or bring it to the show PM sent Share this post Link to post Share on other sites
WHX?? 57,464 #6 Posted April 10, 2024 The ones with the arm seem to operate smoother given a good cable. Also there is more throttle range than just idle or WFO. Share this post Link to post Share on other sites
Racinbob 13,043 #7 Posted April 10, 2024 I modified mine like this. No welding needed. 2 1 Share this post Link to post Share on other sites
squonk 47,421 #8 Posted April 10, 2024 (edited) Making the cable a bit longer helps too. Edited April 10, 2024 by squonk Share this post Link to post Share on other sites
