CCW 1,519 #26 Posted November 21, 2025 On 11/19/2025 at 3:39 PM, Joe BenHayon said: Unfortunately, mine is beyond patching over the crack. The fissures are full depth of the foam. I did separate the cushion from the pan and am formulating a plan to make a new seat from scratch. In my second thread I mentioned how I repaired the foam with some seat foam from an old couch. Used rubber cement to glue the piece in place and then shaped it as best I could with the tools I have. I do not have a wire cutter that would have done a better job, Once covered this is not seen or felt while sitting on it. 2 Share this post Link to post Share on other sites
Joe BenHayon 85 #27 Posted November 27, 2025 Update! I found a local shop and I provided a nice maroon, marine grade upholstery. I cleaned and painted the pan and I really like how it turned out. For $100. 😁😁 2 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #28 Posted November 27, 2025 8 hours ago, Joe BenHayon said: Update! I found a local shop and I provided a nice maroon, marine grade upholstery. . For $100. What was the total cost including cleaners, primer, paint, other shop supplies like sandpaper, foam, the marine grade upholstery, etc? Share this post Link to post Share on other sites
Joe BenHayon 85 #29 Posted November 27, 2025 33 minutes ago, ebinmaine said: What was the total cost including cleaners, primer, paint, other shop supplies like sandpaper, foam, the marine grade upholstery, etc? I cleaned and painted the pan myself. And even supplied the material. $100 for the shops time. The vinyl was leftover from previous project. 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #30 Posted November 27, 2025 9 minutes ago, Joe BenHayon said: I cleaned and painted the pan myself. And even supplied the material. $100 for the shops time. The vinyl was leftover from previous project. Quite a bargain. You did very well. Even figuring a total purchase of all new pieces and supplies I doubt you'd hit $75. Less than $200. I've asked a couple upholstery shops and was quoted $300 - $450. Share this post Link to post Share on other sites
lynnmor 9,040 #31 Posted November 27, 2025 1 hour ago, Joe BenHayon said: I cleaned and painted the pan myself. And even supplied the material. $100 for the shops time. The vinyl was leftover from previous project. Could you expand on how you shaped the foam? 1 Share this post Link to post Share on other sites
Joe BenHayon 85 #32 Posted November 27, 2025 1 hour ago, ebinmaine said: Quite a bargain. You did very well. Even figuring a total purchase of all new pieces and supplies I doubt you'd hit $75. Less than $200. I've asked a couple upholstery shops and was quoted $300 - $450. Thanks. I had another shop here in town quoted me that high too. But they were thinking all new foam. The owner of the shop that did this is an old (er) school biker, been doing it since Noah needed a seat. 😁 He peeled the old material off and saved the foam. 1 2 Share this post Link to post Share on other sites
Joe BenHayon 85 #33 Posted November 27, 2025 30 minutes ago, lynnmor said: Could you expand on how you shaped the foam? The shop peeled off the old vinyl and saved the old foam. 2 Share this post Link to post Share on other sites
