AHS 1,674 #1 Posted April 8, 2024 The tractor WAS running fine until the rain came. I think water got in the gas. It’s been a couple years since the ebay carb went on. Ive replaced, fuel pump, fuel line, EBAY carb.. anyway all the fuel system is replaced. The ebay carb on it runs all right. It hunts and hunts. I was thinking of switching back to the regular carb (on the blue towel) its all gone thru, except the Welch plugs. There are two screws on the stock carb. The idle screw up top. The screw mid way down the carb…. What is it? AND how many turns out is. It supposed to be? I hope this works and it runs fine! Thank you! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,159 #2 Posted April 8, 2024 Initial carb settings are just to make it run. Then you need to fine tune it for best performance. Every engine is different. Share this post Link to post Share on other sites
