jdog_kustoms 82 #1 Posted August 27, 2009 curious if it is worth putting hydraulic lift on my charger 9 and what parts would work and what needs done to the rear axle and transmission to run hydraulics any help would be a big help. Share this post Link to post Share on other sites
CasualObserver 3,411 #2 Posted September 1, 2009 Bump.... I was watching this hoping for a reply. I'm mildly interested in doing the same. Have a Charger 9 and access to a lift kit from a C-160. It appears that the Charger 9 used the Sunstrand 90-2046, as did later Chargers and the Bronco 14... both of which were able to be equipped with a hydraulic lift. The C-160 also used a Sunstrand, but it was a 90-1140. Anyone got opinions and/or advice on this? Any reason it shouldn't just bolt up? I know diddly about hydro stuff... so pictures are always nice! :hide: Share this post Link to post Share on other sites
nylyon-(Admin) 8,321 #3 Posted September 1, 2009 Well I have no idea about this specific question BUT the C-120 which Eldon has was fitted with a hydraulic lift kit. I don't have the specific part number, but WH sold a kit to convert the 120's to hydraulic lift. Maybe check the parts viewer in the accessories for a 77 C-120, and get the IPL for the kit. If I recall correctly, aside from the obvious, there is a spring and check ball to be installed in the hydro, then the lines, valve and cylinder. Not sure if this helps or not? Share this post Link to post Share on other sites
