Ex wh1257 61 #1 Posted March 31, 2024 hello everyone, just a question, is there a possibility to release the transmission by means of a screw so that I can push it with gt 14 and d 200, it can be released with a crane, thanks in advance 1 Share this post Link to post Share on other sites
c-series don 10,450 #2 Posted March 31, 2024 There’s no push/tow valve on the Eaton like there is on a Sunstrand. You can push/pull the Eaton but it must be slow and only for short periods. Pulling up on the transmission disconnect lever will not make a difference when it comes to this. 3 Share this post Link to post Share on other sites
Lee1977 7,356 #3 Posted April 16, 2024 On 3/31/2024 at 12:18 PM, c-series don said: There’s no push/tow valve on the Eaton like there is on a Sunstrand. You can push/pull the Eaton but it must be slow and only for short periods. Pulling up on the transmission disconnect lever will not make a difference when it comes to this. Not any difference to the transmisson, but it helps when pushing. You also push the control lever as for forward as it will go while pushing very slow. 1 Share this post Link to post Share on other sites
