Lynn Brown 0 #1 Posted March 26, 2024 Looking for loader specs possible hydraulic pump replacement Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,838 #2 Posted March 26, 2024 https://www.wheelhorseforum.com/search/?q=ark&quick=1&type=downloads_file Share this post Link to post Share on other sites
wallfish 18,781 #3 Posted March 26, 2024 (edited) This is the pump I would replace the Cessna pump with. RPM can be adjusted by pulley size on the pump if need be but I used a 1:1 for the hoe I built. Yeah, they're getting expensive! https://www.northerntool.com/products/concentric-high-pressure-hydraulic-gear-pump-0-517-cu-in-model-g1232c5a300n00-10567 It's made for belt pulley side load so the many you search for, be sure to look for that. Most are designed for direct couple with the engine shaft and will not have a bearing on the pump shaft to handle side load. Edited March 26, 2024 by wallfish 2 Share this post Link to post Share on other sites
