giant_g2 24 #1 Posted March 22, 2024 I was looking through the manual section, but I couldn't find one for my model - 506219. I was trying to find the belt sizes and blade info. I was also interested in how to rebuild/lube the spindles. They don't need it yet, but I was planning the clean and lube most of the other pulleys. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #2 Posted March 22, 2024 506219 does not look like a model number. 36" side or rear discharge deck? Is the center hole in the blade round or a double-D shape? What tractor model is this for? 1 Share this post Link to post Share on other sites
giant_g2 24 #3 Posted March 22, 2024 (edited) This is a rear discharge. The spindles are round with 2 flats. It came with a 1975 B80 the metal tag on it says model 5 0612 9 Edited March 22, 2024 by giant_g2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #4 Posted March 22, 2024 The 5-0621 should have registered but didn't. The 9 makes it a 1974 model. Click on the fuzzy pictures for more info. 2 Share this post Link to post Share on other sites
giant_g2 24 #5 Posted March 22, 2024 Thank you! This information is great. Figures that mine would be the non-greasable ones... 1 Share this post Link to post Share on other sites
JoeM 10,318 #6 Posted March 22, 2024 3 hours ago, giant_g2 said: Figures that mine would be the non-greasable ones.. I have seen those still running at 30 years old. And the bearings are still available. 3 Share this post Link to post Share on other sites
giant_g2 24 #7 Posted March 22, 2024 I hope I'm not asking too much, but are the bearing a standard size? Is there a way to find the part number or size without knocking them out of the housing? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #8 Posted March 22, 2024 Assuming you have the original spindle assemblies the 103119 bearing assembly is not available from Toro but Stens and other aftermarket suppliers still have it. Before investing in new bearings make sure you can still get blades. They were not available for a few years but are now. The unique center hole is what makes them different. and only available from Toro. https://www.partstree.com/search/?type=part&term=8969 The alternative is to replace all the spindle assemblies to a later design that uses blades with a round center hole and readily available blades and individual bearings. 4 Share this post Link to post Share on other sites
peter lena 10,125 #9 Posted March 22, 2024 @giant_g2 opportunity is what you have , those " non serviceable bearings " are easily replaced with same size / type , with wide rubber side shields , fine flat pocket screwdriver , or small flat putty knife, easily , carefully removes the seals , wipe out original vague lubricant , carb cleaner flush , repack with Lucas green chassis grease, 555- deg flash point , will not fail or whine with noise. you might also do over the PTO / MULE drive bearings. you are right there , lay out mule drive , as you tear down , spacers are vital for proper best set up . also look at PTO cone outer sealed bearing any doubt , replace , Napa has them . done all of my decks / drives / related , solid / quiet / smooth . like said , you are right there , eliminate the problem , pete 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #10 Posted March 22, 2024 One of out vendors K&B sells the DD spindles with bearings. 2 Share this post Link to post Share on other sites
giant_g2 24 #11 Posted March 22, 2024 Thank you all for the info! 1 Share this post Link to post Share on other sites
giant_g2 24 #12 Posted March 29, 2024 Hey all, I think I'm just about done with the mower. I see the blades are just about even with bottom of the side of the deck. Are these blades too low, or do they sit this low by design? I'm used to blades that sit an inch or so above the bottom (newer mowers). Share this post Link to post Share on other sites
giant_g2 24 #13 Posted March 31, 2024 I tried it out for a small patch and it worked fine. Thanks for all the help! 3 Share this post Link to post Share on other sites
giant_g2 24 #14 Posted April 5, 2024 I have one safety related question. It seem slide the rear guard is just a straight extension to the deck and that the blades could easily throw balls/rocks/etc backwards. Has anyone tried using beveled washers to change the angle a bit? Something like these. I can't see it causing any problems, so I might give it a try. Just wanted to see if anyone had any input on this sort of thing. 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #15 Posted April 5, 2024 3 hours ago, giant_g2 said: input I've seen pics of a deck that someone had built and installed a different or extended shield. I don't recall the extra length or angle but I believe it was slanted down maybe 30⁰ or 40⁰ and extended 3 to 5 inches so it was an inch or so higher than the bottom of the original deck. I like this idea because it would also keep more dirt and grass clippings out of the transmission. 1 Share this post Link to post Share on other sites
giant_g2 24 #16 Posted April 5, 2024 I'm going to give these a try. I think the flat wedge shape will spread any force out a bit. I think they're also a shallower angle than the 30 deg ones I posted earlier. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #17 Posted April 5, 2024 43 minutes ago, giant_g2 said: I'm going to give these a try. I think the flat wedge shape will spread any force out a bit. I think they're also a shallower angle than the 30 deg ones I posted earlier. I've put these on two RD decks--a 42” and a 36" geared. 4” vinyl cove base. They help A LOT at keeping stuff from blowing or throwing around. 3 1 Share this post Link to post Share on other sites
Brockport Bill 2,553 #18 Posted April 5, 2024 1 hour ago, Handy Don said: I've put these on two RD decks--a 42” and a 36" geared. 4” vinyl cove base. They help A LOT at keeping stuff from blowing or throwing around. Don - i may have originally borrowed "stole" the rear discharge flange idea from you a few years ago ? Put them on a couple 42" r.d decks -- yup, used Vinyl cove base - works perfect !! 4 1 Share this post Link to post Share on other sites
Handy Don 17,735 #19 Posted April 5, 2024 1 hour ago, Brockport Bill said: i may have originally borrowed "stole" the rear discharge flange idea Given how many terrific ideas I’ve gotten from other members, it’s a pleasure to be able to contribute! Glad it’s working for you! 2 1 Share this post Link to post Share on other sites
Brockport Bill 2,553 #20 Posted April 5, 2024 3 minutes ago, Handy Don said: Given how many terrific ideas I’ve gotten from other members, it’s a pleasure to be able to contribute! Glad it’s working for you! the forum is spectacular INVALUABLE resource -- the lifetime knowledge passed along is amazing 1 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #21 Posted April 10, 2024 On 3/29/2024 at 4:38 PM, giant_g2 said: Hey all, I think I'm just about done with the mower. I see the blades are just about even with bottom of the side of the deck. Are these blades too low, or do they sit this low by design? I'm used to blades that sit an inch or so above the bottom (newer mowers). Anyone have any thoughts on this? Share this post Link to post Share on other sites
Handy Don 17,735 #22 Posted April 10, 2024 4 hours ago, ebinmaine said: Anyone have any thoughts on this? And @giant_g2 ... I have seen this alignment before on mowers I’ve assumed to have original spindles and correct blades. Their blades did not have significant “lift” shaping which would increase the hp requirement and affect airflow under the deck. I always assumed the idea of this design was to minimize bending the grass (which might not bounce back) before it reaches the blade and hence get a smoother cut. My first Craftsman 21” fling-the-cuttings-out-the-side push mower needed only 2.5 hp and had nearly flush-to-the-bottom-skirt blade alignment. My current 18” mulching push mower uses a 4.5 hp engine. Its blade is recessed at least an inch above the skirt and the “high lift” blade ends are within 3/16” of the shell. 2 Share this post Link to post Share on other sites
giant_g2 24 #23 Posted April 14, 2024 Thanks! I did mow with this. It worked fine. I had it on the second to highest setting. I would guess the lower setting would require a much smoother/flater yard than mine. I'm still working on the idea ro change rhe angle on the guard to direct it down more. The washers I posted before won't work. The 2 of the 4 bolts holding it on are at a different distance from the edge, it end up that I would need different angled washers for two of the holes. Using the same 4 ends up with a slight gap between the body and the guard. 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #24 Posted April 14, 2024 2 hours ago, giant_g2 said: still working on the idea ro change rhe angle on the guard to direct it down more Might be easier to leave the guard in place and ad the vinyl piece 🤔 Share this post Link to post Share on other sites
giant_g2 24 #25 Posted April 19, 2024 Yeah, but my main concern was stuff the vinyl won't stop, like rocks or baseballs in tall grass. The kids are always leaving stuff in the yard. 1 Share this post Link to post Share on other sites
