CountryRock 199 #1 Posted March 17, 2024 Is there a cross reference for ignition switch 116338? Looking to replace because the existing switch will not hold the key in place. Really don't want to spend $55-$65+ after shipping and tax. Share this post Link to post Share on other sites
953 nut 63,005 #2 Posted March 18, 2024 You can ge one on https://www.ebay.com/itm/266719305824?itmmeta=01HS7E4478RPEC2K95JQYD1BQR&hash=item3e19b5a060:g:dKIAAOSwxpdl8tew&itmprp=enc%3AAQAJAAAA0Av%2FIyGed19Y%2Bch5ORGvITGLFWGu6xrDW9w6GDGpvhRqdUSANtNQVUdtTSyinM%2BEZTJ%2FHUUnzIPaxM4Qir34ENsu%2BbF2SNZQaTRG1RP%2FxLRqCgnBM%2B73CNSw25WNKxjH9fffSCJSZU4HRvmPBXykaiHF9jDp%2BSiRZ8xarGCqTHxcYXRlOlMDvqMhvQS8PcNFLVuOLuQt2TYa3hsxIDk85VvVGHYlMQhqtL9phAkIRADUwTGvkm3Al0V6zQxGZTuj1gix0kJN%2FO38w7ptShu4N8A%3D|tkp%3ABk9SR9jDkO7JYw Share this post Link to post Share on other sites
CountryRock 199 #3 Posted April 19, 2024 (edited) On 3/17/2024 at 8:11 PM, 953 nut said: You can ge one on https://www.ebay.com/itm/266719305824?itmmeta=01HS7E4478RPEC2K95JQYD1BQR&hash=item3e19b5a060:g:dKIAAOSwxpdl8tew&itmprp=enc%3AAQAJAAAA0Av%2FIyGed19Y%2Bch5ORGvITGLFWGu6xrDW9w6GDGpvhRqdUSANtNQVUdtTSyinM%2BEZTJ%2FHUUnzIPaxM4Qir34ENsu%2BbF2SNZQaTRG1RP%2FxLRqCgnBM%2B73CNSw25WNKxjH9fffSCJSZU4HRvmPBXykaiHF9jDp%2BSiRZ8xarGCqTHxcYXRlOlMDvqMhvQS8PcNFLVuOLuQt2TYa3hsxIDk85VvVGHYlMQhqtL9phAkIRADUwTGvkm3Al0V6zQxGZTuj1gix0kJN%2FO38w7ptShu4N8A%3D|tkp%3ABk9SR9jDkO7JYw Ended up buying this one. It's not an exact plug and play replacement, in fact the one I got is stamped as a Kohler 25 099 39. I had to relocate the run wire to a different spot in the connector and the ground wire had to come out of the connector and attach to the outermost terminal on the switch by itself. After that, everything works as it should. Edited April 19, 2024 by CountryRock Share this post Link to post Share on other sites
