That_patina_856 0 #1 Posted March 13, 2024 So my wheel horse 856 has a 8hp k181 motor. Recently it quit running and I can’t get it running again. At first I thought it may be blown but after looking around a little bit I don’t think that’s the case. I took the carb and head off and did not see anything out of the ordinary. The piston and valves works like they should. I have not been able to take a look at the old oil to see if there are any metal bits in there because the oil cap is round and I do not know how to get it off. I have changed the oil before but I had help then. This motor seemed bulletproof and ran great but I don’t what is wrong with it now because I am not very engine oriented and am still learning about them since I am just a kid. I do have people who do know more about engines and they are taking a look at it this weekend but I was just wondering what you think about this. Share this post Link to post Share on other sites
Sailman 1,306 #2 Posted March 13, 2024 Before worrying about a "blown engine" do a step by step check of spark and fuel. I would start with making sure you have a good spark at the spark plug. You can lay the plug on the head and turn the engine over to see if there is spark. If not replace the plug and if still no spark check the points. May need to replace points and condenser. Once you determine you have spark start working through the fuel supply. Is the gas cap venting air ok? you can pull the gas line off the carb coming from the fuel pump. Is it pumping fuel from the pump when you turn the engine over? If not you may have a plugged gas cap, plugged fuel filter or a bad fuel pump (would need a rebuild or replace). If you have spark and fuel to the carb then I would assume its something plugging the carb and would need a good cleaning. That is just my but I am sure others here will chime in on suggestions. Best of luck! 2 1 Share this post Link to post Share on other sites
That_patina_856 0 #3 Posted March 13, 2024 Thanks I’ll check that I know the pump is sending gas to the carb though Share this post Link to post Share on other sites
Ed Kennell 44,623 #4 Posted March 13, 2024 43 minutes ago, That_patina_856 said: motor seemed bulletproof That they are. Three things are needed to run. I would check for spark first as the other two do not matter if you do not have spark. 1. Fuel and air to the cylinder Clean the air filter and possible clean the carb. 2. A good spark that is timed correctly @Sailman gave you good advice above to check for spark. 3. Compression With the spark plug removed, hold your thumb over the hole and crank the engine. You should feel the pressure. And, to the 1 Share this post Link to post Share on other sites
Pullstart 68,742 #5 Posted March 13, 2024 Yep, like they said above… slow down and cover basics first 1 Share this post Link to post Share on other sites
rmaynard 16,837 #6 Posted March 13, 2024 The simplest thing you can do is to take the cover off of the points and clean the contacts. Letting an engine sit can cause the points to oxidize. Until cleaned, it won't start. 3 1 Share this post Link to post Share on other sites
D_Mac 9,333 #7 Posted March 13, 2024 Also if you are getting spark and fuel, make sure there is no water in the gas. 1 Share this post Link to post Share on other sites
squonk 45,366 #8 Posted March 13, 2024 Is this a mud runner by any chance? Share this post Link to post Share on other sites
Daddy Don 911 #9 Posted March 14, 2024 10 hours ago, That_patina_856 said: Thanks I’ll check that I know the pump is sending gas to the carb though I use fuel filters with a clear case so I can see the fuel moving up to the carb. Share this post Link to post Share on other sites
ANTPER 215 #10 Posted March 14, 2024 When ever unsure of something don't hesitate to reach out to us first before you dive in and spend extra money. All answers here are all the same standard price of free. Start with the simple things first as mentioned above. 2 Share this post Link to post Share on other sites
8ntruck 8,573 #11 Posted March 14, 2024 (edited) A couple more basics - is there gas in the tank, and is the petcock on the fuel tank on? I've been bitten by these two several times. Edited March 15, 2024 by 8ntruck Share this post Link to post Share on other sites
rmaynard 16,837 #12 Posted March 14, 2024 This just happened to me. My 701 ran great at the big show. Engine had been rebuilt prior to. Ran it a few times before putting it away for the winter. Tried to start it yesterday. Nothing. Pulled the plug, wet with gas. Check for spark, okay. Still wouldn't fire. Replace the 8 month old NGK spark plug with a 5 year old Autolite. Fired right up. 1 Share this post Link to post Share on other sites
squonk 45,366 #13 Posted March 14, 2024 Autolites are the only plugs I use in Kohler's 1 Share this post Link to post Share on other sites
rmaynard 16,837 #14 Posted March 15, 2024 Autolite 216 is the best plug that I've used. Can't find them anywhere now. Share this post Link to post Share on other sites
Sailman 1,306 #15 Posted March 15, 2024 3 hours ago, rmaynard said: This just happened to me. My 701 ran great at the big show. Engine had been rebuilt prior to. Ran it a few times before putting it away for the winter. Tried to start it yesterday. Nothing. Pulled the plug, wet with gas. Check for spark, okay. Still wouldn't fire. Replace the 8 month old NGK spark plug with a 5 year old Autolite. Fired right up. I have had the same issue with several small engines (weed eater, etc). I always replace the plug first and it has fixed many a problem. Share this post Link to post Share on other sites
