AJ Desalvo 27 #1 Posted February 22, 2024 Good day members!! I am curious to hear from you folks. Looking to replace my cutting edge. I was able to make one with some scrap metal I had hanging around but the material seems a bit soft. Any suggestions on where to buy new? Thanks in advance. Share this post Link to post Share on other sites
ri702bill 10,803 #2 Posted February 22, 2024 I have had good results using 3/8" thick hot rolled steel. Size it so the holes run up the middle so it is reversable. Holes - hot rolled is a total PITA to drill, so be advised. Check with McMaster-Carr..... Or if you have a local Metal Supermarket. Some folks have switched to urethane or plastic - your choice.... 1 1 Share this post Link to post Share on other sites
oliver2-44 11,092 #3 Posted February 23, 2024 I found a welding shop that had an iron worker with the correct square hole punch. I paid a little more for the metal there. But it sure worked out good for them to use the old blade as a template to punch through. 1 Share this post Link to post Share on other sites
