uk175horse 19 #1 Posted February 19, 2024 (edited) Hi guys, I'm thinking of adding some LED's lights to replace the dead halogens/corroded wiring, and was planning on hooking up to the A - accessory terminal. But checking the ignition switch I seem to have the magneto version - as I can see an M, S, B, I, G? terminal. I have a c175 with K341 engine Its currently wired as M - no connection S - to starter solonoid B - To battery + I - To coil (also linked from coil to rectifier DC+) G - to battery Negative/Ground All works OK (aside from zero safety switches in place!), so do i just ignore and wire LED's straight to the battery or is this going to be causing any longer term issue? I guess the battery will charge as I + B are linked when running? Thanks Edited February 19, 2024 by uk175horse 1 Share this post Link to post Share on other sites
953 nut 70,663 #2 Posted February 19, 2024 Below is a link to the wiring your tractor would have had leaving the factory. If your tractor is performing well and all you wish to do is add the LED lighting there are a couple of options. If the wiring is as shown in the drawing and the light switch has an Orange wire running to it just use that as a power feed. From the sound of your wiring to the ignition switch it may have been rewired with an incorrect switch. If that is the case you could connect a wire to the battery "+" terminal with a 10 Amp fuse, switch and then on to the lights. 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #3 Posted February 19, 2024 Don't recall ever seeing an ignition switch with a M and an I terminal. Could the I possibly be an R or A? 5 Share this post Link to post Share on other sites
wallfish 20,744 #4 Posted February 19, 2024 Just now, gwest_ca said: Don't recall ever seeing an ignition switch with a M and an I terminal. Could the I possibly be an R or A? Same. Don't believe they make that but... The A would still provide power to the coil and connect the regulator back to the battery as it is wired. Best to get the proper battery ignition switch but power for the lights could be taken from that same terminal. The M will ground in the off position so that's why nothing is connected to it. 2 Share this post Link to post Share on other sites
uk175horse 19 #5 Posted February 19, 2024 To be honest I'm going by a photo I took a couple months back, not that clear, so will check if it's definitely an I or R/A. Nothing connected to the light switch but it's still there, need to check it even works! What's the purpose of the G being connected to battery negative, would it even be doing anything ? Share this post Link to post Share on other sites
ssoles 0 #6 Posted February 19, 2024 I have downloaded this and they mention the fuses but have been unable to locate them. Does anyone know where they are physically located? 1978 c165. Share this post Link to post Share on other sites
pfrederi 21,345 #7 Posted February 19, 2024 It is more reliable than grounding through the switch dash panel retainer nut. Mag switches need a reliable ground to stop the engine... 1 Share this post Link to post Share on other sites
Handy Don 17,736 #8 Posted February 19, 2024 1 hour ago, pfrederi said: It is more reliable than grounding through the switch dash panel retainer nut. Mag switches need a reliable ground to stop the engine... Definitely Share this post Link to post Share on other sites
Achto 32,964 #9 Posted February 19, 2024 3 hours ago, uk175horse said: What's the purpose of the G being connected to battery negative, would it even be doing anything ? 2 hours ago, pfrederi said: It is more reliable than grounding through the switch dash panel retainer nut. Mag switches need a reliable ground to stop the engine. If you had a magneto ignition then the "G" terminal would connect to the "M" terminal in the OFF position in order to kill the engine. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #10 Posted February 20, 2024 3 hours ago, ssoles said: I have downloaded this and they mention the fuses but have been unable to locate them. Does anyone know where they are physically located? 1978 c165. Responce in your thread. Share this post Link to post Share on other sites
uk175horse 19 #11 Posted February 21, 2024 The ignition switch was actually marked with L not an I . Bought a waterproof fuse holder now and the light switch is still working, just need to get some PAR LEDs and hook them up. Thanks all 1 1 Share this post Link to post Share on other sites
