sodbuster 1 #1 Posted August 23, 2009 I ended up with a 502 today,but the clutch will not desengage.with the tractor running you cannot put it in gear.any suggestions. thanks Share this post Link to post Share on other sites
Rollerman 290 #2 Posted August 23, 2009 Do you have a belt guard on it?...without it the clutching action won't work correctly. Is the drive belt OEM or a proper length to disangage?...if it's to tight it won't disangage & I've seen a few old Horses with wrong sized generic cheapy belts on them. Once your past the obvious & if your still haveing problems I'd look into the clutch/idler pulley & make sure it's working correct. Share this post Link to post Share on other sites
sodbuster 1 #3 Posted August 23, 2009 havent torn into it yet.it does he belt guard on it.should it have a little play in the belt?? Share this post Link to post Share on other sites
stevasaurus 23,612 #4 Posted August 25, 2009 the tension pully tightens the belt...after you have tried the above, try cleaning the pullys with mineral spirits...the pullys need to be able to slip when the clutch is disenguaged...do not use belt grip on the belt, it is all about the tension. :thumbs2: Share this post Link to post Share on other sites
