Daron1965 644 #1 Posted February 3, 2024 My 312 is put away sleeping in the back of the shed. I can’t easily get to it. Can someone please tell me the diameter of the front spindle? Is it common 3/4 inch? I plan on ordering new rims for the front because of damage. thank you. Share this post Link to post Share on other sites
Ed Kennell 42,078 #2 Posted February 3, 2024 Yes, 312 stock spindles are 3/4" dia. 1 Share this post Link to post Share on other sites
ri702bill 9,462 #3 Posted February 3, 2024 (edited) Should be 3/4" - IF nobody replaced it with a later 1" HD setup. Easy to tell - one retaining clip or screw on the spindle - 3/4" HD would have a castle nut and the rim is held on with 4 lugnuts. Edited February 3, 2024 by ri702bill 1 Share this post Link to post Share on other sites
Daron1965 644 #4 Posted February 3, 2024 Thank you guys. As usual, a wealth of knowledge. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #5 Posted February 3, 2024 Do you have 6" or 8" front wheels? Believe the 312's came with both. 6" allows room for the 37" 2-spindle mower deck. 2 Share this post Link to post Share on other sites
Ed Kennell 42,078 #6 Posted February 3, 2024 1 hour ago, gwest_ca said: Do you have 6" or 8" front wheels? Believe the 312's came with both. 6" allows room for the 37" 2-spindle mower deck. Very good point if you are replacing wheels. My 312 Hydro came with 6" wheels and the longer spindles. I switched it to 8" wheels and left the longer spindles to get more clearance under the front axle for the snow plow frame. I never had a 37" deck, but the 42" deck works fine. The tractor frame is not level sitting higher in the front . Share this post Link to post Share on other sites
