PWL216 1,310 #1 Posted January 28, 2024 I’m trying to get a C-105 to crank over, with a new battery - nothing I’ve done so far has worked… Turn the key, nothing Jumped it at the starter, cranks Jumped it at the solenoid, cranks Apply power to solenoid trigger wire, cranks Replaced the key switch, no crank Bypassed all safety switches, no crank Jumped the ammeter, no crank Checked continuity of all connections, no crank Checked all fuses, no crank ** There is on disconnected wire, shown in pic, that I grounded, no crank. Im fairly sure there’s an incomplete circuit, but I’m not finding it. Any ideas? Thx. IMG_0241.MOV 1 Share this post Link to post Share on other sites
pfrederi 21,345 #2 Posted January 28, 2024 Think your loose wire should go to battery + 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,921 #3 Posted January 28, 2024 Check grounds... My C105 has had several instances where grounds need some love... 1 Share this post Link to post Share on other sites
Ed Kennell 47,955 #4 Posted January 28, 2024 Clutch switch. 2 Share this post Link to post Share on other sites
8ntruck 9,420 #5 Posted January 28, 2024 PTO switch? 1 Share this post Link to post Share on other sites
953 nut 70,663 #6 Posted January 29, 2024 4 hours ago, PWL216 said: Apply power to solenoid trigger wire, cranks Replaced the key switch, no crank At the ignition switch are you getting voltage to the "S" terminal when the key is turned to start? If yes, are you getting voltage to the brake switch input side from your ignition switch when the key is turned to start? With the key turned off test for continuity across the brake switch at rest and when activated, is it working? 1 Share this post Link to post Share on other sites
PWL216 1,310 #7 Posted January 29, 2024 4 hours ago, pfrederi said: Think your loose wire should go to battery + @pfrederi Thank you! This was the problem. I thought I had tried that but apparently I hadn’t. 1 5 Share this post Link to post Share on other sites
