moe1965 774 #1 Posted January 26, 2024 I'm working on a K 181 which has a vacume style fuel pump. I'm not sure if fuel is getting by the seals and getting into the engine. Is there a way to test this I thought about just rebuilding it but why kick a sleeping dog and I'm not to keen on the quality of replacement anything any more. Share this post Link to post Share on other sites
WHX?? 58,388 #2 Posted January 26, 2024 You can plug the outlet and blow into the inlet. If air escapes the diaphragm is ruptured. Wouldn't hurt to disassemble and inspect. I would replace the diaphragm. I believe Buckrancher and Bob Maynard has them. 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #3 Posted January 26, 2024 34 minutes ago, WHX?? said: You can plug the outlet and blow into the inlet. If air escapes the diaphragm is ruptured. Wouldn't hurt to disassemble and inspect. I would replace the diaphragm. I believe Buckrancher and Bob Maynard has them. seconded. Share this post Link to post Share on other sites
RED-Z06 2,720 #4 Posted January 26, 2024 I pull the pulse feed while idling..if theres fuel in the pulse line the pump diaphragm is compromised 1 Share this post Link to post Share on other sites
ri702bill 13,396 #5 Posted January 26, 2024 13 minutes ago, RED-Z06 said: I pull the pulse feed while idling..if theres fuel in the pulse line the pump diaphragm is compromised Reminds me of an old faulty GM Turbo 400 AT Modulator Valve check - if there was ATF in the line, the valve was bad. (A bad one would allow the engine to suck almost all the tranny fluid out!!) Share this post Link to post Share on other sites
WHX?? 58,388 #6 Posted January 27, 2024 (edited) 7 hours ago, RED-Z06 said: I pull the pulse feed while idling..if theres fuel in the pulse line the pump diaphragm is compromised No can do Red ... the pump is bolted to the block and recieves it pulses directly so ther is no pulse line. One of these days went EB is not retired and has the time to doing an instructional of rebuilding them he will do so. I'll help you out EB I have all the pics... Edited January 27, 2024 by WHX?? 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #7 Posted January 27, 2024 36 minutes ago, WHX?? said: No can do Red ... the pump is bolted to the block and recieves it pulses directly so ther is no pulse line. One of these days went EB is not retired and has the time to doing an instructional of rebuilding them he will do so. I'll help you out EB I have all the pics... Why would they use a pulse pump vs mechanical? Share this post Link to post Share on other sites
RED-Z06 2,720 #8 Posted January 27, 2024 So we're all on the same page, K181 has a port below the carb on the front of the block, for a mechanical pump that rides on the cam... A pulse pump operates on crankcase or intake manifold pulses via a hose/fitting or tapping into the case near the top of the crankcase. Which one are we talking about here, both can push fuel into the oil. Share this post Link to post Share on other sites
ebinmaine 81,282 #9 Posted January 27, 2024 24 minutes ago, RED-Z06 said: Why would they use a pulse pump vs mechanical? WHY is always a interesting question. Likely it was a matter of available parts and technology back then. My experience shows me that the pulse type pump on a Kohler K-series works just fine. The diaphragm in a pulse type Kohler pump is easier to replace. Share this post Link to post Share on other sites
ebinmaine 81,282 #10 Posted January 27, 2024 20 minutes ago, RED-Z06 said: So we're all on the same page, K181 has a port below the carb on the front of the block, for a mechanical pump that rides on the cam OR... A pulse type pump Share this post Link to post Share on other sites
RED-Z06 2,720 #11 Posted January 27, 2024 Just now, ebinmaine said: OR... A pulse type pump Its not the same, the name is based on how its driven, pulse type driven by air pulses, or mechanical, driven by a lever. A solenoid style electric, mechanical, and air pulse..all deliver fuel in pulses. Share this post Link to post Share on other sites
Racinbob 13,290 #12 Posted January 27, 2024 (edited) @RED-Z06 Apparently you haven't dealt with a pulse pump on a K series. Go back to Jims post #6. The pump on the right is a pulse style on the K's. The style you pictured is an aftermarket and also used on other engines. Making a plate to cover where the original pump mounts, drilling and tapping it for a hose fitting and you can use the style you pictured. Edited January 27, 2024 by Racinbob Share this post Link to post Share on other sites
RED-Z06 2,720 #13 Posted January 27, 2024 4 minutes ago, Racinbob said: @RED-Z06 Apparently you haven't dealt with a pulse pump on a K series. Go back to Jims post #6. The pump on the right is a pulse style on the K's. The style you pictured is an aftermarket and also used on other engines. Making a plate to cover where the original pump mounts, drilling and tapping it for a hose fitting and you can use the style you pictured. That's why i asked, given the same mounting point, same physical size, why would they opt for 2 separate drive styles (air pulse vs mechanical). 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #14 Posted January 27, 2024 21 minutes ago, RED-Z06 said: Its not the same, the name is based on how its driven, pulse type driven by air pulses, or mechanical, driven by a lever. A solenoid style electric, mechanical, and air pulse..all deliver fuel in pulses. Oh I know it's not the same. We have them both here. Mid 60s 8 HP Kohlers can have either one. I'm talking about the mounting location. 47 minutes ago, RED-Z06 said: K181 has a port below the carb on the front of the block Which may have a mechanical pump... OR A pulse type pump. I write "OR" because I'm not sure if the pumps are interchangeable with one another. Share this post Link to post Share on other sites
ebinmaine 81,282 #15 Posted January 27, 2024 Just now, RED-Z06 said: That's why i asked, given the same mounting point, same physical size, why would they opt for 2 separate drive styles (air pulse vs mechanical). The "why" of every manufacturer is only a guess some 55 years later. My guess... Post # 9. Share this post Link to post Share on other sites
RED-Z06 2,720 #16 Posted January 27, 2024 6 minutes ago, ebinmaine said: Oh I know it's not the same. We have them both here. Mid 60s 8 HP Kohlers can have either one. I'm talking about the mounting location. Which may have a mechanical pump... OR A pulse type pump. I write "OR" because I'm not sure if the pumps are interchangeable with one another. I wonder if the cam has the drive lobe on the air pulse style or if they used a completely different cam? 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #17 Posted January 27, 2024 44 minutes ago, RED-Z06 said: I wonder if the cam has the drive lobe on the air pulse style or if they used a completely different cam? I've wondered that myself. Share this post Link to post Share on other sites
JoeM 10,318 #18 Posted January 27, 2024 As of now, any diaphragm pumps that go bad get electric-fied. Unless your looking for authenticity, electric pumps are the way to go. Easier starting, no fuel in the oil, pumps at all rpm, etc. And the cost is not much more than a good mechanical rebuild kit. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #19 Posted January 27, 2024 14 hours ago, RED-Z06 said: So we're all on the same page, K181 has a port below the carb on the front of the block, for a mechanical pump that rides on the cam... As shown below, same port on the K181 engine has been used by BOTH cam/lever driven and pulse-only pumps. Several threads here have caught this. One might think that with a well-functioning breather that there wouldn’t be enough crankcase pressure change to make this work, but when you look a the area of the diaphragm and the very small amount of movement needed to pump adequate fuel for each combustion cycle, it is clear that it can (and does) work. Of course, this probably requires a tank above or very near the pump level but this was true of most WH’s and, I suspect, ALL of those that used K181s. 14 hours ago, WHX?? said: 1 Share this post Link to post Share on other sites
