WHX?? 57,641 #26 Posted January 13, 2024 6 hours ago, RED-Z06 said: Cant get either of his sites to work, i ordered the same reg off ebay a few minutes ago, will take a week to get here. Sounds good ... check the description very carefully. Some of these regs are only three terminal ones. They do not have the L terminal. All horses used the four term ones because of the cigar lighter and possibly lights. Not a huge deal breaker. They will still work. Share this post Link to post Share on other sites
J854D 145 #27 Posted January 13, 2024 9 hours ago, WHX?? said: Field coils are common as dirt but a PIA to replace. those screws are in there tight. 9 hours ago, WHX?? said: @RED-Z06, back in the day, I worked at an auto/ag electrical repair shop. We changed a lot of field coils using an impact driver to loosen and tighten the screws on the field case. Worked well. Loosening goes a bit easier if you put the ball of a ball peen hammer on the screw head and hit it with another hammer. It distorts/caves in the screw head slightly making them come out easier. Eventually our shop got a jig to remove and replace field case screws. It worked slick! -JD- Share this post Link to post Share on other sites
RED-Z06 2,718 #28 Posted January 13, 2024 2 hours ago, WHX?? said: Sounds good ... check the description very carefully. Some of these regs are only three terminal ones. They do not have the L terminal. All horses used the four term ones because of the cigar lighter and possibly lights. Not a huge deal breaker. They will still work. This one is on a 702, its pretty no frills. If I could find oem lights id go that route. Share this post Link to post Share on other sites
RED-Z06 2,718 #29 Posted January 13, 2024 1 hour ago, J854D said: @RED-Z06, back in the day, I worked at an auto/ag electrical repair shop. We changed a lot of field coils using an impact driver to loosen and tighten the screws on the field case. Worked well. Loosening goes a bit easier if you put the ball of a ball peen hammer on the screw head and hit it with another hammer. It distorts/caves in the screw head slightly making them come out easier. Eventually our shop got a jig to remove and replace field case screws. It worked slick! -JD- Hopefully it doesnt come to that, but im up for the challenge if need be. Share this post Link to post Share on other sites
