Wayne0 1,527 #1 Posted January 3, 2024 I had my 520 snow machine in the garage today for maintenance and noticed the blower doesn't sit flat on the floor. Right side is a good 1" higher. I don't see any adjustment for that. Straightened out one of the impeller blades. I didn't know they were so soft! I also noticed the PTO bell is cracked! I guess that's on the "to do" list. Share this post Link to post Share on other sites
ri702bill 11,419 #2 Posted January 3, 2024 (edited) 17 minutes ago, Wayne0 said: Straightened out one of the impeller blades. I didn't know they were so soft! I have done the same several times with my mid 1970's Ariens 24" Sno Thro. Picking up a chunk of ice can do that - if they were hardened, they would probably break... Edited January 3, 2024 by ri702bill Share this post Link to post Share on other sites
wallfish 19,400 #3 Posted January 3, 2024 34 minutes ago, Wayne0 said: I also noticed the PTO bell is cracked! That's basically a grenade waiting to go off if you run it like that. Dangerous Blower may sit crooked when raised but should always sit flat when lowered ALL the way. Uneven air pressure in the rear tires will cause the frame to sit crooked and therefore the blower too. Too strong of a spring could lift the right side ( assuming we are looking at it from the seat.) Share this post Link to post Share on other sites
Wayne0 1,527 #4 Posted January 3, 2024 14 minutes ago, wallfish said: That's basically a grenade waiting to go off if you run it like that. Dangerous Blower may sit crooked when raised but should always sit flat when lowered ALL the way. Uneven air pressure in the rear tires will cause the frame to sit crooked and therefore the blower too. Too strong of a spring could lift the right side ( assuming we are looking at it from the seat.) I'll check the pressure and I need to order a bell! Share this post Link to post Share on other sites
wallfish 19,400 #5 Posted January 3, 2024 3 minutes ago, Wayne0 said: I'll check the pressure and I need to order a bell! Some adjustment can be made by air pressure in the rears too. Like to make up for some slop in the Tach A Matic connection. Probably check that area too Share this post Link to post Share on other sites
Wayne0 1,527 #6 Posted January 8, 2024 Solved. Left rear tire had NO air!! Share this post Link to post Share on other sites
