Wayne0 1,666 #1 Posted December 22, 2023 So, what's the biggest battery I can put in my 520H? Those little "lawn tractor" batteries don't last very long here. Share this post Link to post Share on other sites
WHX?? 58,388 #2 Posted December 22, 2023 GT12 group U1L in the 230 CCA size is what I run with good life. I don't think the battery space can take anything larger. Since my 520s are winter workers and need to crank in zero temps I go for the 300 CCA but I have seen them in 400. These batteries it's luck of the draw on how long they last. I have gone 6 years and some only 3. Same brand. You sure you don't have a hidden charging/discharging issue? 2 Share this post Link to post Share on other sites
peter lena 10,127 #3 Posted December 22, 2023 @Wayne0 check out Walmart U1L 300 cca , for a same size , improved cold cranking amps , also use battery tenders on my 3 horses , have the electrical leader plug in on choke cable , so its always easy to hook up . also think the tenders add life to battery , lets you keep them full up in cold weather , mine are all in cold sheds . pete 2 Share this post Link to post Share on other sites
peter lena 10,127 #4 Posted December 22, 2023 @Wayne0 check out last photo , of battery tender plug in , very simple to plug in , thats what you want ,pete Share this post Link to post Share on other sites
wallfish 20,744 #5 Posted December 22, 2023 29 minutes ago, WHX?? said: GT12 group U1L in the 230 CCA size is what I run with good life. I don't think the battery space can take anything larger. Since my 520s are winter workers and need to crank in zero temps I go for the 300 CCA but I have seen them in 400. These batteries it's luck of the draw on how long they last. I have gone 6 years and some only 3. Same brand. You sure you don't have a hidden charging/discharging issue? Are you having hard start issues too? Like it's cranking for a long time if the tractor sits for a few days? 1 Share this post Link to post Share on other sites
lynnmor 9,081 #6 Posted December 22, 2023 Get a 350CCA battery made by East Penn, there are a number of brands out there, I bought Duracell last time. Skip the cheap 230 CCA junk. 2 1 1 Share this post Link to post Share on other sites
Wayne0 1,666 #7 Posted December 23, 2023 4 hours ago, wallfish said: Are you having hard start issues too? Like it's cranking for a long time if the tractor sits for a few days? No, just wa-wa then click, click. Just bought a 300 cca from wally world. We'll see how that stands up. I probably should get a tender as well. 2 Share this post Link to post Share on other sites
WHX?? 58,388 #8 Posted December 23, 2023 5 hours ago, lynnmor said: Skip the cheap 230 CCA junk. You sir obviously ain't got thirty tractors to feed or have really deep pockets. Who in Gods great creation is East Penn? I ain't exactly in Kansas anymore Toto. The cheap 230's from Wally work fine in my small bores and even in the big ones. Just don't expect 4-5 years out of one. They are just like bearings ... designed to wear out. Yes Wayne a battery tender can extend the life considerably. My winter 520s have one on them regardless of season. Those are the ones I get most longevity out of. 5 hours ago, wallfish said: Are you having hard start issues too? Like it's cranking for a long time if the tractor sits for a few days? Yes 'Fish that sadly does come into play and even with the check valve ... unless you fitted a electric fuel pump.. Share this post Link to post Share on other sites
wallfish 20,744 #9 Posted December 23, 2023 1 hour ago, Wayne0 said: No, just wa-wa then click, click. Just bought a 300 cca from wally world. We'll see how that stands up. I probably should get a tender as well. Ah. was hoping for and easy fix because heavy drains like that reduce battery life The batteries we can get now a days don't seem to last more than a couple /few years. I was proud of one I had on my vintage looking WH bike that had a sticker from 03. Sadly we're not going to see ANY new batteries last 20 years any more 1 Share this post Link to post Share on other sites
WHX?? 58,388 #10 Posted December 23, 2023 (edited) 12 minutes ago, wallfish said: Ah. was hoping for and easy fix because heavy drains like that reduce battery life The batteries we can get now a days don't seem to last more than a couple /few years. I was proud of one I had on my vintage looking WH bike that had a sticker from 03. Sadly we're not going to see ANY new batteries last 20 years any more 20 Fish? Now yer on crack but I get what yer sayin. Edited December 23, 2023 by WHX?? 1 Share this post Link to post Share on other sites
wallfish 20,744 #11 Posted December 23, 2023 (edited) 20 minutes ago, WHX?? said: 20 Fish? That battery with a sticker from 03 just got changed out this year. That's no BS either. If'n ya had that white stick with old man sandles outta the way, maybe we could zoom in the battery! LOL Edited December 23, 2023 by wallfish 2 Share this post Link to post Share on other sites
oliver2-44 11,850 #12 Posted December 23, 2023 Heat and cold also play a role in battery life. 2 Share this post Link to post Share on other sites
lynnmor 9,081 #13 Posted December 24, 2023 On 12/22/2023 at 9:39 PM, WHX?? said: You sir obviously ain't got thirty tractors to feed or have really deep pockets. Who in Gods great creation is East Penn? The cheap 230's from Wally work fine in my small bores and even in the big ones. Just don't expect 4-5 years out of one. From their website: A private, family-owned company operating the largest single-site, lead battery manufacturing facility in the world. I do expect and get 5 years or more from a good battery, YMMV. 1 Share this post Link to post Share on other sites
HorseFixer 2,015 #14 Posted December 26, 2023 (edited) Like others have mentioned, Don't buy cheap stuff! I buy Duralast Gold from Autozone and have that in my 520-H I keep a Harbor Freight Viking Microprocessor 4 Amp Charger plugged into all my Battery Tractors and have more Things Powered up on my 520 than 10 tractors. You wont loose a battery with a float charger hooked up. Edited December 26, 2023 by HorseFixer 1 Share this post Link to post Share on other sites
Wayne0 1,666 #15 Posted December 29, 2023 Impressive! You work for NASA? On another note, my tender came in yesterday. Where do you 520H guys mount them? Share this post Link to post Share on other sites
