Jaxxon 9 #1 Posted November 28, 2023 (edited) Hey guy - Just got done with a full rebuild on this P220 on a JD 420. I have one white wire with a small eye let that comes out of the 3 prong plug with 2 others that go to the Voltage reg. The 3 prong plugs wires are Brown,Red,Orange. Wire in question connects to the orange on the plug. It has a smaller eyelet and it has key on 12 volts. Any help where this goes would be appreciated. Thanks in advance. Jax Edited November 28, 2023 by Jaxxon Added model number of tractor Share this post Link to post Share on other sites
Achto 32,252 #2 Posted November 28, 2023 5 minutes ago, Jaxxon said: Any help where this goes would be appreciated. Not sure what year your tractor is but check out our manuals for a wire diagram. Example: Share this post Link to post Share on other sites
Jaxxon 9 #3 Posted November 28, 2023 (edited) Sorry man, its for a JD 420. Ive dug through a ton of wiring schematics and with lack of color code it makes it difficult to guess where a live wire goes. Ill dig through the one you posted. TY bud Edited November 28, 2023 by Jaxxon spelling 1 Share this post Link to post Share on other sites
WHX?? 57,642 #4 Posted November 29, 2023 Jax 21 minutes ago, Jaxxon said: Sorry man, its for a JD 420. And finding that wiring diagram you might have to invest heavily in JD stock. The wire that powers up the ig coil? Just grasping thoughts buddy. Much as I loathe to say it you might be better off finding your answer on a green n yellow site or try tractor talk.com. Share this post Link to post Share on other sites
Jaxxon 9 #5 Posted November 29, 2023 (edited) Hey bud, yea I've gleamed a lot of info and manuals off this site for the onan so figured I'd join and ask here first. The coil does have a black,red and condenser wire meant for that just not connected in the picture. Appreciate the advice,help and as much as it pains you the direction elsewhere. Edited November 29, 2023 by Jaxxon Spelling 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #6 Posted November 29, 2023 There is a couple of diagrams on page 8-7 of the Onan manual. Share this post Link to post Share on other sites
Jaxxon 9 #7 Posted November 29, 2023 Yea I have that manual and a couple others. None have the correct wiring schematic that I'm working with. Appreciate the info however. Share this post Link to post Share on other sites
Streetrodchev 1,165 #8 Posted November 29, 2023 Ill take a picture shortly of my 318, it will be similar to your 420. 2 Share this post Link to post Share on other sites
Jaxxon 9 #9 Posted November 29, 2023 2 minutes ago, Streetrodchev said: Ill take a picture shortly of my 318, it will be similar to your 420. Appreciate that. Share this post Link to post Share on other sites
WHX?? 57,642 #10 Posted November 29, 2023 2 minutes ago, Streetrodchev said: Ill take a picture shortly of my 318, it will be similar to your 420. Not the one that had a short and started on fire on the plow field Jeff? No wait that was Pullstart... 2 Share this post Link to post Share on other sites
Streetrodchev 1,165 #11 Posted November 29, 2023 (edited) Just confirmed, it goes to the coil + terminal. Edited November 29, 2023 by Streetrodchev 1 Share this post Link to post Share on other sites
Streetrodchev 1,165 #12 Posted November 29, 2023 1 1 Share this post Link to post Share on other sites
WHX?? 57,642 #13 Posted November 29, 2023 Wow talk about a wild $hit house guess Jeff. Guessing again it goes to the positive post? Thing that tipped me off as I think I saw the coil in his pic with nothing on the terms. Share this post Link to post Share on other sites
Jaxxon 9 #14 Posted November 29, 2023 7 minutes ago, Streetrodchev said: Ok so out of those 3 white/color stripe 2 go to the VR and is there a 3rd that goes or bolts so where with small eyelet? Share this post Link to post Share on other sites
Streetrodchev 1,165 #15 Posted November 29, 2023 They go to coil + center terminal on the voltage regulator oil pressure sensor Share this post Link to post Share on other sites
Jaxxon 9 #16 Posted November 29, 2023 (edited) 22 minutes ago, Streetrodchev said: Just confirmed, it goes to the coil + terminal. So the coil + has 2 key on power going to it? MY coil has on POS term: Red wire (hot key on power) and condensor wire, NEG Term has the Black/ground wire. Edited November 29, 2023 by Jaxxon description Share this post Link to post Share on other sites
Streetrodchev 1,165 #17 Posted November 29, 2023 16 minutes ago, WHX?? said: Wow talk about a wild $hit house guess Jeff. Guessing again it goes to the positive post? Thing that tipped me off as I think I saw the coil in his pic with nothing on the terms. I was pretty sure it was the coil +, but wanted to confirm before I posted. 1 Share this post Link to post Share on other sites
Jaxxon 9 #18 Posted November 29, 2023 2 minutes ago, Streetrodchev said: They go to coil + center terminal on the voltage regulator oil pressure sensor Oil pressure already has a spayed/forked connection on it. I remembered where that went. The white/hot wire wont reach the oil sensor. Share this post Link to post Share on other sites
Streetrodchev 1,165 #19 Posted November 29, 2023 1 minute ago, Jaxxon said: So the coil + has 2 key on power going to it? Mine has a red (pos) with key on power, Black (Ground) and a condensor wire to POS. The coil + should have 3 wires, condenser ign module red wire and the white wire from that 3 terminal plug the coil - should only have the black wire from the ign module Share this post Link to post Share on other sites
Streetrodchev 1,165 #20 Posted November 29, 2023 The oil pressure sensor only gets that one wire Share this post Link to post Share on other sites
Jaxxon 9 #21 Posted November 29, 2023 1 minute ago, Streetrodchev said: The coil + should have 3 wires, condenser ign module red wire and the white wire from that 3 terminal plug the coil - should only have the black wire from the ign module Or does it have 4 wires? White/Red/Condenesor and 1 on black ground side? Share this post Link to post Share on other sites
Streetrodchev 1,165 #22 Posted November 29, 2023 That red (hot) wire on the coil that you mentioned, where does the other end go? Thinking that was a previous owner modification. Share this post Link to post Share on other sites
Jaxxon 9 #23 Posted November 29, 2023 (edited) 3 minutes ago, Streetrodchev said: That red (hot) wire on the coil that you mentioned, where does the other end go? Thinking that was a previous owner modification. Comes off the ignition module, I always called it a pick up coil.. Labeled "Ignition Control" in schematics. Its all stock from stator to pick up coil. 1 owner machine btw. That white wire has to be the 3rd in the schematic and my brain didnt want to see it.. or something. Edited November 29, 2023 by Jaxxon Share this post Link to post Share on other sites
Streetrodchev 1,165 #24 Posted November 29, 2023 Coil + has 3 wires red from the ign control (pickup coil) condenser white wire with ring terminal from the three terminal plug. Share this post Link to post Share on other sites
Jaxxon 9 #25 Posted November 29, 2023 3 minutes ago, Streetrodchev said: Coil + has 3 wires red from the ign control (pickup coil) condenser white wire with ring terminal from the three terminal plug. In that wiring schematic i see 4 POS has Red from ignition control,condensor and the 3rd wire comes from #4 it looks then ground from ignition control Share this post Link to post Share on other sites
