Fire_rescue_18 0 #1 Posted August 20, 2009 I have a 310-8 that has a bad carb. I cant find one anywhere!! Is it an easy swap if I find an M12??What engines will bolt up easily?? Share this post Link to post Share on other sites
kpinnc 16,234 #2 Posted August 20, 2009 I won't try and tell you what to do with your machine, but a Kohler carb would be easy to find on Ebay, and carb kits are VERY easy to install as well- if you decided to fix yours. You can buy a carb kit from NAPA of all places for about $12. But to answer your question, a M10, M12, M14, or even M16 will be a easy swap. Also a K241, K301, K321, or K341 would be the same thing. Any of these engines will swap with your M10. Kevin Share this post Link to post Share on other sites
Fire_rescue_18 0 #3 Posted August 20, 2009 The throttle shaft is worn and sucking air. I have looked all over ebay and various other sites to get a shaft and bushing kit or replcement carb. No luck!! It's my only tractor and I need it runing asap. Price is not important. Share this post Link to post Share on other sites
rustbucket 4 #4 Posted August 20, 2009 http://gardentractorpullingtips.com/a1carb.htm chech with this guy here he dose remanufacturing of certain carbs and what not he might be able to help you out . Share this post Link to post Share on other sites
Kelly 1,035 #5 Posted August 20, 2009 If money is no issue a new carb should only be about $100-150 try tulsa engine warehouse for a carb. Share this post Link to post Share on other sites
Kelly 1,035 #6 Posted August 20, 2009 Look at the first one on this page not sure if it's right or not but it's a start, http://tewarehouse.com/Catalog/0552 Share this post Link to post Share on other sites
