Manuel 8 #1 Posted November 27, 2023 Hello, just purchased a used snowthrower, researching info, I believe the belt should be 64.5 inches. Please can anyone confirm? Thanks. The gearbox between the augers was dry, I put in gear lube and it started to leak from the right side so I will order 2 seals, pn 7-0045 , now I see another gearbox where the chain is located, my question= is there a way to drain the oil and refill without having to remove the box from its location? I see I can remove the cover but there’s like a drain plug but is located in the bottom making it hard to refill from there. Love my 520h, I’m the original owner and it has been a great tractor for sure. Thanks for your time, I’m new here. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #2 Posted November 27, 2023 Drive belt 116332 (HB x 64.50" or 5/8" x 64.5") 1 Share this post Link to post Share on other sites
cleat 7,679 #4 Posted November 27, 2023 Mine has an L565 on it and it fits fine. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #6 Posted November 27, 2023 10 hours ago, gwest_ca said: Drive belt 116332 (HB x 64.50" or 5/8" x 64.5") Since you will not find belts in fractional inch lengths I checked Gates and Napa and they recommend 5/8"x65". Sometimes they round up and others they round down. I know they will have checked the fitment. 1 Share this post Link to post Share on other sites
Manuel 8 #7 Posted November 27, 2023 Thanks, I went ahead and ordered an OEM from toro, called a few dealers and none had them. Would you by any chance know if there is a service book one can get so I can work on this attachment? Toro dealer told me to go to toro.com and all the info is there but it is not, there you can find parts list and how to use their products. Trying to get info in the gearbox that the chain rides on. Thanks for your help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #8 Posted November 27, 2023 Here is everything we have on the 06-44SC01 model 1 Share this post Link to post Share on other sites
wallfish 18,628 #9 Posted November 28, 2023 On 11/26/2023 at 8:46 PM, Manuel said: now I see another gearbox where the chain is located, my question= is there a way to drain the oil and refill without having to remove the box from its location Those Peerless gearboxes are filled with grease, not oil. You will need to pull it off and remove the plate to get access for removing the grease and re packing it full 1 Share this post Link to post Share on other sites
peter lena 9,471 #10 Posted November 28, 2023 @Manuel agree with @wallfish on the grease replacement , would also verify the temp range on that , especially on the cold side , for easiest protection . also check for movement gain / verification as you do this service . using the belt connection area as your movement start . found numerous , issues / hang ups in any , belt driven unit . just don't take for granted that its all going to move easily . also like SUPER LUBE , liquid synthetic on related cables , connections , etc. excellent cold weather movement . local hard ware store $ 6. brought a 44" back to life , was frozen with neglect , good luck , Pete Share this post Link to post Share on other sites
