Crow Horse 8 #1 Posted August 19, 2009 What can be done for non greasable spindles? I have a 36" SD deck and want to keep the spindles lubricated. Can I drill & tap for zircs? Share this post Link to post Share on other sites
WheelHorse_of_course 100 #2 Posted August 19, 2009 Adding zerks could be done, but you would want to disassemble first to keep the chips from falling into the spindle. If/when I have the pulley(s) off I do try and work in some 3and1 oil into the top bearing, but it is of limited use I suspect. YMMV! :thumbs2: Share this post Link to post Share on other sites
tarcoleo 120 #3 Posted August 28, 2009 Those bearings are probably equipped with seals so that relubrication might be difficult and not easily accomplished with a squirt. Such seals can be overcome with pressure obtained with grease fittings swamp yankee Share this post Link to post Share on other sites
WheelHorse_of_course 100 #4 Posted August 28, 2009 Those bearings are probably equipped with seals so that relubrication might be difficult and not easily accomplished with a squirt. Such seals can be overcome with pressure obtained with grease fittings swamp yankee If you rotate the bearing the oil works it way in despite the sheild. The more time you spend, the more you can get it. But it is tedious. I did this one one of the old cat iron idler pullies with the replaceable bearng. I had not got around to getting the replacement bearing and I could tell it was dry. The oil definitely made a difference in this case and a year later it still doesn't feel dry. I do need to get a replacement bearing though. :scratchead: Share this post Link to post Share on other sites
tarcoleo 120 #5 Posted August 28, 2009 Rolf, I don't know what the situation is in this case, but bearings come in three ways, unshielded, shielded and sealed. Given that there seems to be no provision here for relubrication, I would suppose that the bearings are sealed for life, the usual case where dirt and other contaminants are to be excluded. Sometimes these bearings are only shielded. But like I say, not sure what gives here. Your idea of carefully drilling and tapping sounds good. On the other hand, if one can believe these bearing are lubricated for life, perhaps doing nothing is a good solution. Tom in RI :scratchead: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #6 Posted August 29, 2009 I'll admit it is an assumption but... I suspect they are only shielded. My understanding is that the sealed ones are very expensive and not seen much outside special applications like food processing. In any case, the one in my idler did take in some oil with some effort rotating the bearing. :scratchead: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #7 Posted August 29, 2009 Tarc With regards to the spindle, the ones I prefer have roller bearing at the bottom and those will most certainly benefit from a shot of grease now and then. I have three of these spindles waiting for refurbishment and thhen to go on my spare parts shelf. Two of those have threaded holes I believe are for zerks, though the they are not the same size. I'll have to take them to the auto parts store and get the right zerks. The third one has no hole, but it will before that one gets re-assembled. :scratchead: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted August 29, 2009 Lots of good ideas but they might be worthless if the 36" deck spindles in question are the wrong type. Quite a few of these 70's era smaller decks had a bearing assembly like this (a.k.a. P/N 103119): You can drill the spindle housing and insert all the zerks you want and the grease will never get near the bearings. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ @Crow Horse: Do you have a model number for this deck? :scratchead: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #9 Posted August 29, 2009 Lots of good ideas but they might be worthless if the 36" deck spindles in question are the wrong type. Quite a few of these 70's era smaller decks had a bearing assembly like this (a.k.a. P/N 103119): Excellent point Terry I don't like that kind because I can't rebuild them. :hide: Share this post Link to post Share on other sites
tarcoleo 120 #10 Posted August 29, 2009 Bearing pictured by TT is a sealed unit. This type of bearing has been used widely, as in auto water pumps for example. swamp yankee Share this post Link to post Share on other sites
Crow Horse 8 #11 Posted September 9, 2009 @Crow Horse: Do you have a model number for this deck? I received a new spindle bearing and now can see that it's sealed and zerks installed in the spindle housing won't be of any use. Well, it was a noble effort but to no avail......... My deck is a # 5-0722, 36" SD, 1975.... The bearing it uses is a 103119................... Share this post Link to post Share on other sites
can whlvr 994 #12 Posted September 9, 2009 I just did the bearings in my 1974 36 rear discharge,stens offers them now as the originals are not to be found at the dealer,at least up here in omtario.they were 50 a peice,ouch!! Share this post Link to post Share on other sites
