Marty Taylor 4 #1 Posted November 12, 2023 516-H sometimes slows to a crawl. If I move the motion control lever to reverse and back it up, it usually moves at a good pace, but soon reverts back to a slower speed again. I'm thinking there could be something in the motion control lever slowing the speed down... any others experiencing the same? Any recommendations for a fix? Thanks. Share this post Link to post Share on other sites
Ed Kennell 43,101 #2 Posted November 12, 2023 Is the MC lever not staying in the full forward position? Share this post Link to post Share on other sites
lynnmor 8,086 #3 Posted November 13, 2023 If you have the Eaton 1100 hydro then read this thread. Share this post Link to post Share on other sites
Marty Taylor 4 #4 Posted November 13, 2023 Thanks Lynnmor. Your response on the Eaton 1100 hydro is greatly appreciated. Share this post Link to post Share on other sites
Marty Taylor 4 #5 Posted November 13, 2023 Ed, Correct... the MC lever will NOT stay in the full forward position, it drops back to a slower speed. Share this post Link to post Share on other sites
Ed Kennell 43,101 #6 Posted November 13, 2023 18 minutes ago, Marty Taylor said: Ed, Correct... the MC lever will NOT stay in the full forward position, it drops back to a slower speed. Common problem and an easy fix. Just follow Lynns instruction. 1 Share this post Link to post Share on other sites
kpinnc 15,713 #7 Posted November 14, 2023 The 516-H uses the 700 series Eaton. Share this post Link to post Share on other sites
Handy Don 14,658 #8 Posted November 14, 2023 20 hours ago, kpinnc said: The 516-H uses the 700 series Eaton. For the 700, get and read this manual. The motion control (MC) linkage is nearly entirely the same parts but arranged slightly differently and the adjustment as well. Share this post Link to post Share on other sites
Tuneup 1,452 #9 Posted November 15, 2023 If your 516 is like mine, the linkage from lever to trans can use a good inspection and possibly repair. I had to also replace the cam and ground on it for a faster reverse. The Eaton 7 works much better for me on 15E-50 synthetic. She'd overheat on 20 weight. I do keep the clamping force on the cam on the loose side as I mow with lever in hand. She's just a bit too worn to lock in position, especially considering my up and down yard. Gets the job done. 1 Share this post Link to post Share on other sites
