Cjwv1975 117 #1 Posted November 8, 2023 I downloaded the owners manual but cant seem to find a parts list. I need a spring for the parking brake, rear axle seals and possibly seal for the drive wheel. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #2 Posted November 8, 2023 2 Share this post Link to post Share on other sites
ebinmaine 79,639 #3 Posted November 8, 2023 10 minutes ago, Cjwv1975 said: I downloaded the owners manual but cant seem to find a parts list. I need a spring for the parking brake, rear axle seals and possibly seal for the drive wheel. The spring will be a 108035 I believe. Shop carefully. They can be had online for 12 to 15 bucks shipped to your door. The transmission seals are ordered most easily from our own vendor Wheelhorsepartsandmore. Get all 4 seals. Also order 2 or 4 NEW set screws. I have some here I can mail ya. You'll want to pop out the set screws ASAP and start the penetrating oil soaking in there. Hubs are... Well they're a pain. A right of passage if you will. Procure the appropriate puller. Be VERY patient. Share this post Link to post Share on other sites
Cjwv1975 117 #4 Posted November 8, 2023 26 minutes ago, ebinmaine said: The spring will be a 108035 I believe. Shop carefully. They can be had online for 12 to 15 bucks shipped to your door. The transmission seals are ordered most easily from our own vendor Wheelhorsepartsandmore. Get all 4 seals. Also order 2 or 4 NEW set screws. I have some here I can mail ya. You'll want to pop out the set screws ASAP and start the penetrating oil soaking in there. Hubs are... Well they're a pain. A right of passage if you will. Procure the appropriate puller. Be VERY patient. What puller do you recommend. I know the long finger pullers are frowned upon Share this post Link to post Share on other sites
ebinmaine 79,639 #5 Posted November 8, 2023 10 minutes ago, Cjwv1975 said: What puller do you recommend. I know the long finger pullers are frowned upon The one I have is home shop made. I'd recommend doing a good search on the site to see the options. Hydraulic jacks can be even better used with the right set-up. To say the 3 jaw puller is frowned upon is correct... And putting it lightly. The chances are VERY high that will break the hub. Share this post Link to post Share on other sites
daveoman1966 3,884 #6 Posted November 8, 2023 (edited) Go here: https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en Enter your model # as B-100... clik SEARCH. You see a list of B-100 models. Clik on your MODEL NUMBER...all sorts of schematics will pop up, giving you OEM part numbers for everything. As to the hub: this puller has never fialed me...make it from an old hub and nuts/bolts from any hardware. Edited November 8, 2023 by daveoman1966 4 Share this post Link to post Share on other sites
