brodi3man 0 #1 Posted August 18, 2009 Not a wheel horse i know but hoping someone can point me in the right direction. I have a 72 economy powerking w/ 14hp kohler when first starting, it doesn't like to stay running. I start it, back it out of the garage and it starts stahling out. I then have to baby it with starting fluid and work the throttle for a few minutes then its fine. Any thoughts on what is causing this? Share this post Link to post Share on other sites
WHC-125 4 #2 Posted August 18, 2009 I would start off with taking the carb off and cleaning it out really thoroughly and putting fresh gaskets in it and test it out. Also, a fresh plug as well and it should fix the problems you are having because it seems like the carb is gunked up. Share this post Link to post Share on other sites
brodi3man 0 #3 Posted August 18, 2009 Thanks WHC! I'll give that a run and see what happens. Brodi3man Share this post Link to post Share on other sites
brodi3man 0 #4 Posted August 19, 2009 Just wanted to drop a picture in for you all. I know a post is 1000times better with a pic. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #5 Posted August 19, 2009 I have the sister machine however it is a 1969 with hydro lift. I agree with Chris that you may have some gunk in the carb bowl. These machines are just powerhouses-I love mine !! I am having a three point installed on mine as we speak. Good luck- Share this post Link to post Share on other sites
WHC-125 4 #6 Posted August 19, 2009 brodi3man, Great looking Economy and good luck on getting it all set. :thumbs2: Share this post Link to post Share on other sites
