Sparky
Let’s talk TIRES
sjoemie himself
6 hours ago, Handy Don said:
29psi...
 Was mostly done to seat the bead since it was a tubeless tire. Customer came to pick it up and told me they run them at around 8 to 12psi normally.
RED-Z06
My 416 just barely clears 24s without raising the fender, like...dont get your fingers between the tire and fender.
ebinmaine
Same on my '74 C160-8
Stan50
Guys, I bought 2 turf tires 18x8.5x8 ,probably out of Husqvarna(rear ones), with 3/4" center bore,no bearings?,with key.
What can do with that? I was thinking about front tires,but these ones are maybe too big or wide (I've got regular 6"). Probably will need different spindles?.
I have 22x7.5x12 rear ones. Second purpose is my diy trailer, turf tires would be perfect fit.
Handy Don
Yep, probably too big for fronts (rub on frame? bore length?)
Garden trailer seems likely, or some other implement.
