AlexR 3,112 #226 Posted March 8 1 hour ago, HyperPete said: Now that is interesting to me, I was not aware that I should drop the tire pressure with beet juice! This likely contributed to my lack of traction in the snow. I have the same tires, I'll reduce them to 5 psi. It's not just having them fluid filled even non filled you will get more traction with lower psi, on low speed tractors like Wheelhorse's there are probably only about 2 reasons to run higher psi on rear tires 1- Mowing shouldn't need lots of traction (unless very hilly) and less chance of tearing up grass with higher psi 2- Heavy loads, don't want the tires really bulging. Make sure your valve stem is at the top before letting air out when fluid filled. You probably already know that, but just in case you didn't. 1 Share this post Link to post Share on other sites
AlexR 3,112 #227 Posted March 8 13 hours ago, ebinmaine said: Mine are not mounted yet, no. I wish I had measured mine before mounting, I don't remember what they measured and didn't take a photo of a measurement either. 2 Share this post Link to post Share on other sites
HyperPete 939 #228 Posted March 9 On 3/8/2026 at 12:36 PM, ebinmaine said: Having lower air pressure isn't a requirement for fluid filling specifically. It helps with keeping more of the tread on the ground surface by making the flat part at the bottom longer and wider. Are you using chains? not yet, on my list! 1 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #229 Posted March 9 1 minute ago, HyperPete said: not yet, on my list! Speaking from experience. That's your traction problem. 3 Share this post Link to post Share on other sites
kpinnc 18,960 #230 Posted April 24 An unusual size and tread on these: OTR Grassmaster in 22x12-12 size. Typically used on commercial ZTRs. Actual measurements are 22 inches tall, 11.5 wide. Probably would make true 12 inch width on 10 inch wide wheels. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #231 Posted April 24 53 minutes ago, kpinnc said: OTR Grassmaster in 22x12-12 size. Actual measurements are 22 inches That's good to see. My OTR Lawn Trac are also nearly a full size of the listing. 2 Share this post Link to post Share on other sites
kpinnc 18,960 #232 Posted April 24 3 hours ago, ebinmaine said: That's good to see. My OTR Lawn Trac are also nearly a full size of the listing. The last four tires I've bought were OTR. They are a bit expensive compared to the no name stuff on the jungle site (I've had good luck with those so far as well), but they seem to be very good quality. Time will tell on the longevity of course... But all four of those tires are accurate on sizing. They do measure what is written on the sidewalls. 3 1 Share this post Link to post Share on other sites
gt14rider 1,278 #233 Posted May 15 Hi all, what's a good inner tube, may fluid fill in future. Lot of tubes to choose from, some aren't cheap,but are they any good. 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #234 Posted May 15 3 minutes ago, gt14rider said: Hi all, what's a good inner tube, may fluid fill in future. Lot of tubes to choose from, some aren't cheap,but are they any good. I've had a similar dilemma in the last couple years. Right or wrong I have no idea yet.... But I chose tubes that were made in either India or Vietnam. They seemed okay when I got them. 1 Share this post Link to post Share on other sites
702854boy 1,149 #235 Posted May 15 I've used the either ag pro or ar pro brand that is on amazon, I don't fully remember what the exact name is but they have worked good for the tires I've done even though I haven't fluid filled them. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #236 Posted June 29 New C-81 purchase came with 22x7.50’s, would have been 23x8.50’s when new. Amazing how much height diff there is! 4 Share this post Link to post Share on other sites
ineedanother 2,864 #237 Posted June 29 1 hour ago, Sparky said: New C-81 purchase came with 22x7.50’s, would have been 23x8.50’s when new. Amazing how much height diff there is! That might mow grass well with 6" front rims, otherwise maybe not so much. Share this post Link to post Share on other sites
Handy Don 17,474 #238 Posted June 29 (edited) 1 hour ago, Sparky said: New C-81 purchase came with 22x7.50’s, would have been 23x8.50’s when new. Amazing how much height diff there is! And probably almost 5% slower with the 22’s! Edited June 29 by Handy Don 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #239 Posted June 30 On 6/28/2026 at 10:06 PM, Handy Don said: And probably almost 5% slower with the 22’s! Once I’m done servicing the C-81 it’ll get the new “racing” 23’s 4 Share this post Link to post Share on other sites
ebinmaine 80,695 #240 Posted June 30 10 minutes ago, Sparky said: Once I’m done servicing the C-81 it’ll get the new “racing” 23’s Why don't you quit screwing around and step it right up to a 24. Imagine all that extra speed. 3 Share this post Link to post Share on other sites
JCM 11,415 #241 Posted June 30 I mowed with the new 1989 312-8 with stock 15 x 6.00 fronts and 22 x 9.00 rears until 2000 on a 1/2 acre lot and a 42 SD deck. Striped the lawn nicely. Tractor was a pleasure to mow with coming from a rear engine Ariens. Like night and day. The 312-8 has basically been retired since 2000 with an occasional cruise around the yard. 1 1 Share this post Link to post Share on other sites
Bugzilla46310 50 #242 Posted August 19 On 6/30/2026 at 3:10 PM, JCM said: I mowed with the new 1989 312-8 with stock 15 x 6.00 fronts and 22 x 9.00 rears until 2000 on a 1/2 acre lot and a 42 SD deck. Striped the lawn nicely. Tractor was a pleasure to mow with coming from a rear engine Ariens. Like night and day. The 312-8 has basically been retired since 2000 with an occasional cruise around the yard. What about the Chevelle? Share this post Link to post Share on other sites
JCM 11,415 #243 Posted August 19 Bought the Chevelle SS a year after High School graduation in 1976 with 17,000 miles on it. Sold it to my BIL who just recently had a new motor built for it along other things. It's much too scary now. It will remain in the family. My nephew will end up with it next. TKS 1 Share this post Link to post Share on other sites
sjoemie himself 3,211 #244 Posted September 7 Soo we had a zero turn (wheel) come in at work with some massive tires on equally massive rims. Was wondering if something like this would fit on a WH. Sure as heck would look cool! Size is 26.5x14.00-12 (will try to take some actual pics and measurements tomorrow). 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #245 Posted September 7 10 minutes ago, sjoemie himself said: wondering if something like this would fit on a WH. Sure as heck would look cool! They'd be super close. If they run small to stamping size they may just fit. Here's my post on 24 x 12 x 12. Share this post Link to post Share on other sites
sjoemie himself 3,211 #246 Posted September 7 13 minutes ago, ebinmaine said: They'd be super close. If they run small to stamping size they may just fit. Here's my post on 24 x 12 x 12. Eric, I've put 26x12-12 on the 512-D with minor seat hightening-adjustemefication.. 24's should fit no problem? 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #247 Posted September 7 1 minute ago, sjoemie himself said: Eric, I've put 26x12-12 on the 512-D with minor seat hightening-adjustemefication.. 24's should fit no problem? My 24s were good. Share this post Link to post Share on other sites
Lee1977 7,772 #248 Posted September 7 (edited) 2 hours ago, sjoemie himself said: Soo we had a zero turn (wheel) come in at work with some massive tires on equally massive rims. Was wondering if something like this would fit on a WH. Sure as heck would look cool! Size is 26.5x14.00-12 (will try to take some actual pics and measurements tomorrow). 312-8 with 25 x 900 x12. 78 and later models have a bar under the back of the footrest. earlier models don't have that bar. The fender bracket, gas tank and fender was raised 1 3/4". Edited September 7 by Lee1977 2 Share this post Link to post Share on other sites
sjoemie himself 3,211 #249 Posted September 8 Some actual measurements on the 'steamrollers'.. Width: 14-3/16" (@29psi) Height: 26-3/4" (@29psi) Rim dia: 12" Brand: Carlisle Type: Ultra Trac Size on tyre: 26.5x14.00-12 1 Share this post Link to post Share on other sites
Handy Don 17,474 #250 Posted September 8 3 hours ago, sjoemie himself said: Width: 14-3/16" (@29psi) Height: 26-3/4" (@29psi) 29psi...isn’t that like driving on wooden wheels?! 1 Share this post Link to post Share on other sites
