Sparky
Let’s talk TIRES
Handy Don
On 10/25/2025 at 12:52 PM, 702854boy said:
I think this tire has another 40 years of use in it
Shredded and used under NFL artificial turf, maybe
sqrlgtr
Swapped out some 23-8.50 Deestone for 23-8.50 carlisle. Raised tractor by a little over an inch and probably 1/2” or more wider. You may have to enlarge oics to see differences and last pic is with one each on traactor.
RED-Z06
Yes Deestones run extremely small, i sent a set back this year because their 23x10.50-12 measured 21x9.50-12..
sqrlgtr
:text-yeahthat: They do run small shame to because they are pretty good tires beside that. I have had those for a least 12yrs.
sqrlgtr
Horseshoe brand 24-12-12 tires. They are a little over 23.5” tall with a width of around 12” sidewall to sidewall right at 11” across tread. Picture beside an older 23-10.50-12 for comparison. Weight 89.6 lb. With rim gaurd. On 9.5 inch rim.
Edited by sqrlgtr
ebinmaine
Niiiiice fat meats.
sqrlgtr
Wifey caught me with her floor scale and wanted to know why I had it out in shop. I told her I had to replace the springs she had stretched out in it. Took her a minute but she didnt find that response to funny :D
  • Haha 1
ebinmaine
HAHAHAHAHAHAHAHAHA
Handy Don
And how long until the temperature went back to normal?
  • Haha 1
sqrlgtr
Still pretty cold in here.:occasion-snowman:
RED-Z06
I ordered a pair of Tiron 10.5 wide wheels to put on my loader tractor, i hated how the old 26x12x12 lugs had bulged out and rounded.  So, i had wheels but the wheels had 1/2" holes, i bought spacers with the right size studs but the 7/16 lug bolts wouldn't hold the spacers, so i bought 7/16-20 all-thread, and 7/16-20 lug nuts, and made my own bolts, got the wheels on to realize that the wheels are flat, no lug centric pockets, so I ordered some flat faced 7/16-20 lug nuts, got a set of 26x12x12 Tru-Powers on, ballast in, and weights installed.  Game changing setup for stability and traction. So, this is what 26x12x12 tru-power tires look like on 10.5 wide wheels.
Handy Don
Most all-thread is pretty low-grade steel unless you specifically look for the stronger stuff
RED-Z06
Grade B7 125,000 tensile strength.
kpinnc
Posted (edited)
Got some new tires that I thought would be a good reference here.
Armstrong "Big Bite" 16x8.50-8. 4 ply rated. Actual measurements are dead on 16 inches tall, 8 and 3/8 wide.
First pic is one next to a 7.50 wide tire, next beside the old Firestone 6.50 tri ribs.
Mounted on 8x7 wheels.
Edited by kpinnc
  • Excellent 5
David414
Great look! Where did you get those rims? Will the larger tires interfere with the mowing deck?
sqrlgtr
The wheels came off an older Craftsman mower. Not sure on deck? I haven't had a deck on this particular tractor in a long time. I think they would be alright but really not fer sure. :confusion-shrug:.
AlexR
Here is the run down on the BKT TR-315 23x10.50-12
-7.5" wide rim
-Less then 5 psi fluid filled
-22.5" height
-8 3/4" width
Deestone (left) vs BKT Right
Deestone (left) vs BKT (right)
  • Thanks 2
ebinmaine
14 minutes ago, AlexR said:
8 3/4" width
Interesting how yours are so much narrower than mine.
I have a set that measures 9.5 inches across.
SylvanLakeWH
Common problem... same brand, same marked "size"... different country of manufacture... go figure... :(
AlexR
Are yours mounted on a rim and inflated any?
I do like how the BKT's tread is a flatter on the edges then the deestones. Both tires on are the same size rim and should be close to the same psi.
Edited by AlexR
kpinnc
Rim width has a big effect on how wide the tire spreads, and how flat the tread and sidewalls end up. Especially true for ag cleats.
ebinmaine
Mine are not mounted yet, no.
Tonytoro416
Tread or lugs on a new tire do no good if only 70% of them actually come into contact with the surface.  When setting up my 416 I was not settling for anything less than a flat contact patch. Makes a world of difference if your tires are hunting for traction and your able to give them all that’s available
