Chris1986 1 #1 Posted October 17, 2023 I have a 1994 toro wheel horse 264-6 with a 38" deck. My bearings are shot and can't get a part number off them. Would anyone know what the part number would be. It's the spindle bearings. Thank you. Share this post Link to post Share on other sites
Ed Kennell 45,048 #2 Posted October 17, 2023 3315-188_1992_38in_SD_R5-38SL02_Recycler_IPL.pdf to the Chris. Is this your deck? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #3 Posted October 18, 2023 https://www.partstree.com/models/78215-toro-38-side-discharge-mower-deck-for-260-series-tractors-sn-049000001-049999999-1994/ https://www.partstree.com/models/78216-toro-38-side-discharge-mower-deck-for-260-series-tractors-sn-049000001-049999999-1994/ https://www.partstree.com/models/78218-toro-38-side-discharge-mower-deck-for-260-series-tractors-sn-069000001-069999999-1996/ 2 Share this post Link to post Share on other sites
Chris1986 1 #4 Posted October 18, 2023 Yes. Thank you Share this post Link to post Share on other sites
Ed Kennell 45,048 #5 Posted October 18, 2023 17 minutes ago, Chris1986 said: Yes. Thank you Garry has posted links to the parts that are available. If the bearings are not available, You may take an old one to a bearing supplier where they can measure and match it to one that is available. NAPA may do this for you. Share this post Link to post Share on other sites
squonk 45,630 #6 Posted October 18, 2023 (edited) Bearing # 6204-RSJ Common Bearing ID. 20MM OD. 47MM THK. 14MM Edited October 18, 2023 by squonk Share this post Link to post Share on other sites
