wheelhorsejoe 4 #1 Posted October 17, 2023 If I replace my fuel pump with and electric pump do I need to install a pressure regulator? Thanks Joe 1 Share this post Link to post Share on other sites
953 nut 62,162 #2 Posted October 17, 2023 This thread should give you all the information you need. 3 Share this post Link to post Share on other sites
squonk 44,618 #3 Posted October 17, 2023 I've installed 2 Napa 610-1051 (Facet) electric pumps on 2 tractors with no regulator and no issues. 5 Share this post Link to post Share on other sites
AHS 1,563 #4 Posted October 20, 2023 On 10/17/2023 at 7:26 PM, squonk said: I've installed 2 Napa 610-1051 (Facet) electric pumps on 2 tractors with no regulator and no issues. Is the fuel pump using the A on the key switch? 1 Share this post Link to post Share on other sites
953 nut 62,162 #5 Posted October 20, 2023 8 minutes ago, AHS said: Is the fuel pump using the A on the key switch? You should fuse the feed to the pump and can can use the "A" terminal or on a battery ignition unit the fuel pump can be connected to the "I" terminal. 3 Share this post Link to post Share on other sites
peter lena 9,455 #6 Posted October 20, 2023 @wheelhorsejoe https://www.amazon.com/CarBole-Universal-2-3-5P-S-I-Operating-Self-Priming/dp/B01IR6BNKY/ref=asc_df_B01IR6BNKY/?tag=hyprod-2 have a couple of these in use , regulate themselves , also have a fuel check valve close to carb , holding , insuring fuel to carb , clear fuel line , also hooked up a single LED GREEN , bulb on dash, to verify running when ignition is on , not needed , but like its ok reference . you will have to get a fuel pump engine cover plate , to cover fuel pump removal point . over all electrics have been very good for me . pete 4 Share this post Link to post Share on other sites
