FloydT 0 #1 Posted September 28, 2023 What do you guys use/recommend as a suitable replacement for the 16x5.50-8 front tires? Something that somewhat looks correct and correct height? Thanks Share this post Link to post Share on other sites
Skwerl58 831 #2 Posted September 28, 2023 What wheel width do you have or tractor model? Older tractors had narrow wheels around 4 inches and the newer had around 6 inch wheels. I just bought a trailer tire from Walmart for my 1054, a 4.80x8 that was only around $20 per tire and they fit the tractor great. Your tractor should be able to handle the 16x6.50x8 tires with no problem. Lots of new tires are under sized compared to the older tires. Lots have replaced tires using Deestone tri ribs just depending on application and tractor usage. Some others will chime in shortly. 3 Share this post Link to post Share on other sites
oliver2-44 11,735 #4 Posted September 28, 2023 here are some that are close to the old saw-tooth" tread design https://www.summitracing.com/parts/CRR-519067?seid=srese1&gclid=CjwKCAjwkPX0BRBKEiwA7THxiHQ_7gUrsv75yKZM4k6xFHionXegqTTMipx1xoyA_VFzj5b2xzkpRBoCDv8QAvD_BwE Share this post Link to post Share on other sites
Lee1977 7,764 #5 Posted September 28, 2023 Deestones 400 x 8 4 ply diameter 16.7" got mine from Greater Cleveland Tire listed under tractor tires . You can find Greater Cleveland Tire listed under tire suppliers In Redsquare LInks..They require tubes Share this post Link to post Share on other sites
