scotty 252 #1 Posted September 27, 2023 Hi im checking if anyone has put on a 6.5 predator with a bell pto and if the shaft would be long enough? Share this post Link to post Share on other sites
oliver2-44 11,071 #2 Posted September 28, 2023 The Predator engines don’t have the thrust bearing on their crankshaft required for the use of the bell PTO. WH specifically spec’d the Kohler and Tecumseh engines to have a thrust hearing to handle the load created by the cam lever action that engages the bell PTO. You should consider using an electric clutch PTO on a Predator. This is what WH used when it used Briggs engines that did not have a thrust capable crankshaft bearing. 1 Share this post Link to post Share on other sites
