Rob J. 1,945 #1 Posted September 27, 2023 I have this 854 and I’m doing a little maintenance on. I’m rebuilding the trans and fixing a leaky gas tank. I have everything apart and started cleaning the old gasket off. I was going to just red kote the tank but once I got it off the “do it right” in me kicked in and I split the tank. My question to the guys here that have a lot of experience in these two piece tanks is what’s the best method to seal it right? Do you just use the gasket? Or do you use the gasket and a liquid gasket as well? How about the sequence in which once you have the gasket(s) in place to place the screws back in what order? I appreciate any feedback. Gitty up! 1 Share this post Link to post Share on other sites
ri702bill 13,399 #2 Posted September 28, 2023 Inside of tank looks clean! Guy on the 'Bay sells a new material water jet cut gasket that will work with ethanol gas. Already did two.....Comes with instructions and a recommendation for sealer..... Bill 1 Share this post Link to post Share on other sites
Pullstart 71,567 #3 Posted September 28, 2023 21 minutes ago, ri702bill said: work with ethanol gas wha-wha-what? 1 hour ago, Rob J. said: I appreciate any feedback. I highly recommend KBS 3 part sealer. No more worrying about a future leak! 1 Share this post Link to post Share on other sites
moe1965 774 #4 Posted September 28, 2023 I I did a tank on my 854 about 4 years ago I got lucky and all the screws came out fine surprisingly I ran a bottoming tap in every hole installed a new gasket and staggered my re assembly of the screws back to what I thought was right going across from the one I just tightened. Don't squish the gasket and you should be fine. 1 Share this post Link to post Share on other sites
JoeM 10,318 #5 Posted September 28, 2023 I have used this stuff on fuel tanks. Works real good. 1 Share this post Link to post Share on other sites
Rob J. 1,945 #6 Posted September 28, 2023 Has anyone replaced the gasket and then once that was done Red-Kote the inside of tank? 1 Share this post Link to post Share on other sites
Wild Bill 633 943 #7 Posted September 28, 2023 Dow DOWSIL 730S. Although very expensive. Share this post Link to post Share on other sites
dclarke 4,274 #8 Posted September 28, 2023 I used a new gasket, coated on both sides with Yamabond 4 gasket sealer. Make sure your mating surfaces are flat. Share this post Link to post Share on other sites
Racinbob 13,290 #9 Posted September 28, 2023 I think you were headed in the right direction right off the get go. Clean the tank. Once you have it clean, clean it again. Let it dry several days. Plug the bottom hole with a PVC plug just in case. Pour a little Red-Kote in (maybe 1/4 cup max, just enough to coat the bottom outside edge). Swirl the tank so it flows around the gasket seam. Go in both directions. Let it set up several more days. Prepare yourself to never have to worry about those pesky two piece tank leaks again. My only complaint is that they don't sell it in much smaller cans. I have a quart can and have done three two piece tanks and the can still looks full. 2 Share this post Link to post Share on other sites
Darrenw85 764 #10 Posted September 28, 2023 I've seen a couple that had been welded, no future problems fixing that way. 1 Share this post Link to post Share on other sites
Handy Don 17,739 #11 Posted September 28, 2023 16 hours ago, Rob J. said: I split the tank Mucho congrats on getting the tank split without breaking off any of the 15 little rascals that hold it together! I wasn’t successful on mine so ended up with a replacement one-piece from a 701. Share this post Link to post Share on other sites
