d -bunked 6 #1 Posted September 26, 2023 How do you adjust steering play in a 1978 d-160 Share this post Link to post Share on other sites
Achto 29,408 #2 Posted September 26, 2023 (edited) 1 hour ago, d -bunked said: How do you adjust steering play in a 1978 d-160 Where is the play? If it is in the gear box you can tighten the adjustment screw on the Ross box. Explained in section 8 in the manual for your tractor. If it is in the tie rods, replace the ends. Edited September 26, 2023 by Achto 2 Share this post Link to post Share on other sites
Lee1977 7,216 #3 Posted September 26, 2023 First check all the tie rod and steering rod ends. If they are loose you need new ones, I would suggest new Heims Joints. they will last longer then the ball joint ends. The the holes in the spindles may also worn causing loose steering. 2 Share this post Link to post Share on other sites
