heysavoy 22 #1 Posted September 15, 2023 Hi. I am hoping someone can help me? I have a 1990 WH tractor Model 31-12KE01 and while cutting today my steering stopped. Image 3672 is after I had put it back on but of course it didn't stay after making another turn or two. One of the rods came out. (IMG 3675) I believe this is called a tie rod? Am I correct? If so it seems these are the two parts (see image # 3676 below) I need to have replaced. (One works but shouldn't I go ahead and do both?) If it's not necessary to replace both... which part # is the one on the left if you are sitting in the driver's seat? They look the same to me. If not the correct part # does anyone have the correct one? I appreciate any assistance you can give me. This site has been awesome as It's given me the confidence (with a little help) to make some repairs in the past I never thought I could. 2 Share this post Link to post Share on other sites
ri702bill 11,671 #2 Posted September 15, 2023 Yes, BOTH sides need to be replaced. due to age and one potentially catastrophic failure. No room for Band-Aids.... Some of us (me) and others make our own using Heim joints. Lowell in the Vendors section sells quality modern replacements. Adjustable length, modern tech. is the only way to go... Bill 2 Share this post Link to post Share on other sites
ebinmaine 78,072 #3 Posted September 15, 2023 $71 EACH??? Yeah definitely get ahold of Lowell at Wheelhorse Parts And More. 3 Share this post Link to post Share on other sites
heysavoy 22 #4 Posted September 16, 2023 6 minutes ago, ebinmaine said: $71 EACH??? Yeah definitely get ahold of Lowell at Wheelhorse Parts And More. I'm not familiar with that portion of the site. How do I get hold of him to make sure I'm ordering exactly what I need? Thanks Eric!! 2 Share this post Link to post Share on other sites
Sparky-(Admin) 24,909 #5 Posted September 16, 2023 https://www.wheelhorseforum.com/forum/141-wheelhorse-parts-and-more/ 2 1 1 Share this post Link to post Share on other sites
Achto 31,451 #6 Posted September 16, 2023 (edited) 1 hour ago, heysavoy said: They look the same to me. If not the correct part # does anyone have the correct one? Here is a direct link for Lowell's tie rods $58 for the pair. They also have replaceable ends that are available at most hardware stores for the next time they need replacing. https://wheelhorsepartsandmore.com/product/toro-wheel-horse-tie-rod-78-2900-78-290001-longer-length-with-replaceable-ends-with-nuts/ For a temporary fix you can remove your old tie rods, place the ball back in the hole, & hammer the side down to keep the ball from popping out. Will get you through until your new ones arrive. Edited September 16, 2023 by Achto 1 1 Share this post Link to post Share on other sites
ebinmaine 78,072 #7 Posted September 16, 2023 13 minutes ago, heysavoy said: I'm not familiar with that portion of the site. How do I get hold of him to make sure I'm ordering exactly what I need? Thanks Eric!! From the main page scroll down to Classified, Vendors, Wheelhorse Parts And More. Open their site. Here's a cut/paste of the contacts. 2 Share this post Link to post Share on other sites
Sparky-(Admin) 24,909 #8 Posted September 16, 2023 8 minutes ago, Achto said: For a temporary fix you can remove your old tie rods, place the ball back in the hole, & hammer the side down to keep the ball from popping out. Will get you through until your new ones arrive. Temporary Dan? Lol! I had one that I repaired like that and it worked for years. Put a smear of grease in the socket first, then peened it….keeping it greasy 2 2 3 Share this post Link to post Share on other sites
ebinmaine 78,072 #9 Posted September 16, 2023 3 minutes ago, Sparky said: keeping it greasy Pete would approve. 2 1 2 Share this post Link to post Share on other sites
heysavoy 22 #10 Posted September 16, 2023 28 minutes ago, Achto said: Here is a direct link for Lowell's tie rods $58 for the pair. They also have replaceable ends that are available at most hardware stores for the next time they need replacing. https://wheelhorsepartsandmore.com/product/toro-wheel-horse-tie-rod-78-2900-78-290001-longer-length-with-replaceable-ends-with-nuts/ For a temporary fix you can remove your old tie rods, place the ball back in the hole, & hammer the side down to keep the ball from popping out. Will get you through until your new ones arrive. 28 minutes ago, ebinmaine said: From the main page scroll down to Classified, Vendors, Wheelhorse Parts And More. Open their site. Here's a cut/paste of the contacts. Thank you so much. Super helpful. I so appreciate it. 29 minutes ago, ebinmaine said: From the main page scroll down to Classified, Vendors, Wheelhorse Parts And More. Open their site. Here's a cut/paste of the contacts. Thanks so much!! 3 Share this post Link to post Share on other sites
peter lena 9,821 #11 Posted September 16, 2023 @heysavoy lots of good advise and info here , do what ever is in your thinking , personally always have , threaded rod , and heim joints in my stash , very easy to make up . Lowell's made up ends , looks good to me , pete 2 Share this post Link to post Share on other sites
Racinbob 12,878 #12 Posted September 16, 2023 I've made many sets with these ends, 3/8"-24 rod and 3/8" ID tube stock. Earlier this year I made a pair using heim joints for my B-160. 2 1 Share this post Link to post Share on other sites
Handy Don 16,179 #13 Posted September 16, 2023 (edited) Good use for “re-tie-erd” tie rods? Cut off the ends and the ⅝” rod fits nicely into front Attach-a-Matics for fabrication projects like this: Edited September 16, 2023 by Handy Don 3 Share this post Link to post Share on other sites
squonk 45,960 #14 Posted September 16, 2023 All of these posts and no one has mentioned bailing wire (For country dwellers) or zip ties (for Suburbanites) 1 7 Share this post Link to post Share on other sites
DCwom 78 #15 Posted November 14, 2023 I came across this thread from a bunch of weeks ago and it prompted me to go down and take a look at my Raider 12 tie-rods, I know they are worn out, everything is, she's done a lot. The steering has lots of play, in the pinion, rack and tie-rods, but nothing has let go yet, I see the joints are quite dry, but there are no fittings, how do you grease them, just smear grease and hope it gets in? 2 Share this post Link to post Share on other sites
Handy Don 16,179 #16 Posted November 14, 2023 52 minutes ago, DCwom said: how do you grease them Originally there would have been a rubber boot covering the ball/socket to keep out dirt and to keep lube in but they dry out and fall off after a measly 40 years or so. Sigh. I use an aerosol grease to spray in there, but you can use regular and “smush” it in with latex-gloved fingers. You can ge better coverage if you unbolt them from the tractor, but that adds a lot of time. 2 Share this post Link to post Share on other sites
ebinmaine 78,072 #17 Posted November 14, 2023 1 hour ago, DCwom said: I came across this thread from a bunch of weeks ago and it prompted me to go down and take a look at my Raider 12 tie-rods, I know they are worn out, everything is, she's done a lot. The steering has lots of play, in the pinion, rack and tie-rods, but nothing has let go yet, I see the joints are quite dry, but there are no fittings, how do you grease them, just smear grease and hope it gets in? 37 minutes ago, Handy Don said: Originally there would have been a rubber boot covering the ball/socket to keep out dirt and to keep lube in but they dry out and fall off after a measly 40 years or so. Sigh. I use an aerosol grease to spray in there, but you can use regular and “smush” it in with latex-gloved fingers. You can ge better coverage if you unbolt them from the tractor, but that adds a lot of time. Could also make the switch to greasable Heim joints on the tie rods. 3 Share this post Link to post Share on other sites
Handy Don 16,179 #18 Posted November 15, 2023 10 minutes ago, ebinmaine said: Could also make the switch to greasable Heim joints on the tie rods. I left this suggestion for you! 2 Share this post Link to post Share on other sites
heysavoy 22 #19 Posted November 15, 2023 Thanks for all the advice. I wasn't familiar with aerosol grease (just WD40 but sure it must be different). I ended up getting replacements rods from Lowell at Wheelhorse Parts And More. and they worked great not to mention at a great price. Let's hope they last another 30 years. 2 3 Share this post Link to post Share on other sites
Lee1977 7,632 #20 Posted November 15, 2023 On 9/16/2023 at 12:41 PM, squonk said: All of these posts and no one has mentioned bailing wire (For country dwellers) or zip ties (for Suburbanites) We don't use bailing wire it's electric fence wire. 1 3 Share this post Link to post Share on other sites
Handy Don 16,179 #21 Posted November 15, 2023 3 hours ago, Lee1977 said: We don't use bailing wire it's electric fence wire. On one tractor I keep a length of wire wrapped around the steering wheel spokes so it’s handy for emergency repairs! I always get questioned about “What is this wire for?” Contingencies, man, contingencies! 3 Share this post Link to post Share on other sites
