stegs 327 #1 Posted August 30, 2023 Morning everyone Last night i picked up a 42" side discharge deck and mule drive. Mower deck model 78345 Need a mule drive belt Tractor is a c-141 8 speed I found someone in a past post saying its a 88" mule drive belt, some say its a 98" Both agreed its a 1/2" belt Anybody got a actual size that will fit? i will grab one on my way home from work Share this post Link to post Share on other sites
peter lena 10,089 #2 Posted August 30, 2023 @stegs opportunity, why not clean out and re grease those mule drive bearings ? very easy to carefully pop off the rubber side shields , small flat pocket screwdriver , small putty knife. wipe out , carb cleaner flush , repack Lucas green grease , 550 deg rated , no whyining noise , solid smooth , also lay out the drive as you take it apart , note spacer mounting layout , this is critical for operation . also lube the adjustment screw , any related attachment points . done this on my 3 horses. , easy pete Share this post Link to post Share on other sites
ri702bill 13,189 #3 Posted August 30, 2023 Download the manual for that mower deck. In the sidebar to download, it should list the common available belt size... Bill 1 Share this post Link to post Share on other sites
pfrederi 21,222 #4 Posted August 30, 2023 WH 94-2501 103" Share this post Link to post Share on other sites
stegs 327 #5 Posted August 30, 2023 thank you all! Ill grab one on my way home 2 Share this post Link to post Share on other sites
