Doc995 1 #1 Posted August 30, 2023 Hello all, new to the group! I just picked up a very nice Toro 265H and need to replace the deck blades....any tips or advice on it's removal? Thanks in advance! Share this post Link to post Share on other sites
Ed Kennell 46,578 #2 Posted August 30, 2023 to the Doc. I am not familiar with the 200 series tractors, but someone that is should be here soon to help. Meanwhile, try to locate the operators manual in our manuals section. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,352 #3 Posted August 30, 2023 You posted the model and serial of the tractor. Do you have the same for the mower deck? or What is the width of cut and how many blades? Side or rear discharge? 2 Share this post Link to post Share on other sites
Doc995 1 #4 Posted August 30, 2023 Thank you both....I'll check that deck for #'s and post here! Great forum, btw! 1 Share this post Link to post Share on other sites
Doc995 1 #5 Posted September 2, 2023 Ok, found the deck model # Share this post Link to post Share on other sites
Ed Kennell 46,578 #6 Posted September 2, 2023 3322-353 1999-2003 48in SD 78261 OM.pdf Here is the OM for your deck. Scroll down for removal instructions. Share this post Link to post Share on other sites
WHX?? 57,390 #7 Posted September 2, 2023 (edited) It's pretty easy. Worse part is muscling it out from underneath. It that a cracked bracket on top of the model sticker? Edited September 2, 2023 by WHX?? Share this post Link to post Share on other sites
Doc995 1 #8 Posted September 5, 2023 Thanks guys! That bracket is actually the plastic cover for the top of the blade mandrel (looking down on the deck from driver's seat) but you're right, it DOES look like a metal bracket from the angle I shot it! Share this post Link to post Share on other sites
