Searcher60 209 #1 Posted August 29, 2023 Anybody know if anybody is currently selling the rubber floorboard treads? Mid 80’ style to mid 90’s type with the adhesive backing. Or, where to buy the material so i can cut them myself if nobody is cutting them. Thanks! Share this post Link to post Share on other sites
Stormin 9,988 #2 Posted August 29, 2023 I use the skate board tread tape. Adhesive backed and easily cut. Any sports shop should stock it. 2 1 Share this post Link to post Share on other sites
ri702bill 12,915 #3 Posted August 29, 2023 Harbor Fright sells a heavy 12" x 12" diamond tread self stick rubber pad - about $5. I did the ones on the C81 - cut the piece with a tablesaw. Heat the underside of the metal with a heat gun - make removing the old ones easy.... Install with the sawcut edge facing in... 1 Share this post Link to post Share on other sites
lynnmor 9,026 #4 Posted August 29, 2023 Search for rubber-cal fine rib mat, maybe you can find a self adhesive type or a spray adhesive that will work. Share this post Link to post Share on other sites
Lee1977 7,756 #5 Posted August 30, 2023 The rubber pads make a great place for rust, I took them off my 520 and sanded and repaired the rusted areas then tossed them in the trash. Share this post Link to post Share on other sites
rjg854 13,330 #6 Posted August 30, 2023 1 minute ago, Lee1977 said: sanded and repaired the rusted areas then tossed them in the trash. you went to all that work and then tossed them in the trash 1 Share this post Link to post Share on other sites
953 nut 68,806 #7 Posted August 30, 2023 18 hours ago, Stormin said: skate board tread tape Skateboard grip tape comes in colors and designs too. 1 Share this post Link to post Share on other sites
Lee1977 7,756 #8 Posted August 30, 2023 1 minute ago, rjg854 said: you went to all that work and then tossed them in the trash Yes, the Rubber Pads they were not in great shape. I have some rubber pad similar to the HF pads, but I won't put it on a tractor. Share this post Link to post Share on other sites
Lee1977 7,756 #9 Posted August 30, 2023 (edited) double post Edited August 30, 2023 by Lee1977 Share this post Link to post Share on other sites
Handy Don 17,382 #10 Posted August 30, 2023 3 hours ago, 953 nut said: Skateboard grip tape comes in colors and designs too. This is my fave as well. Easily trimmed and full-face adhesive prevents water from entering underneath. 2 Share this post Link to post Share on other sites
rmaynard 17,553 #11 Posted August 30, 2023 Rubber-Cal 03_167_W_RC_04 Ramp Cleat Non-Slip Outdoor Rubber Floor Mats, 0.13 inch Thick X 3ft X 4ft, Black Available from Amazon 2 Share this post Link to post Share on other sites
Searcher60 209 #12 Posted August 31, 2023 22 hours ago, rmaynard said: 22 hours ago, rmaynard said: Rubber-Cal 03_167_W_RC_04 Ramp Cleat Non-Slip Outdoor Rubber Floor Mats, 0.13 inch Thick X 3ft X 4ft, Black Available from Amazon Fantastic! Did you use 2 sided tape or glue? Thanks! Rubber-Cal 03_167_W_RC_04 Ramp Cleat Non-Slip Outdoor Rubber Floor Mats, 0.13 inch Thick X 3ft X 4ft, Black Available from Amazon 1 Share this post Link to post Share on other sites
rmaynard 17,553 #13 Posted August 31, 2023 (edited) I used double-sided carpet tape called Rhino tape. Edited August 31, 2023 by rmaynard 1 Share this post Link to post Share on other sites
