Matt0000 1 #1 Posted August 21, 2023 When turning the throttle rpm’s don’t rise till about it’s halfway up then it randomly jumps and rises rpm’s. What could this be bad cable ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #2 Posted August 21, 2023 Most likely the way the outer cable casing is secured at the engine end. Loosen the clamp and pull the casing back away from the engine a bit and retighten. 1 1 Share this post Link to post Share on other sites
8ntruck 8,667 #3 Posted August 21, 2023 Might be caused by some crud in the linkage between the governor and the carb. See if you have a build up of gunk there. If so, clean it up with carb spray. 1 Share this post Link to post Share on other sites
peter lena 9,797 #4 Posted August 22, 2023 @Matt0000 typically , cables are laid out , WHERE THEY DO NOT WANT TO BE , have rerouted and smoothed out function as I went , also added a few screw on cable clamps at related screw trim spots , used SUPER LUBE , synthetic lube to drip thru the length of cable , very smooth / easy function . have also added small pull springs to my cable levers , to constantly assist cable movement , pull . like having a very smooth easy cable . definetly works , pete Share this post Link to post Share on other sites
