Nathan W 5 #1 Posted August 8, 2023 I have an auto 16. What is the difference between the 73 auto 16 and the 74 75 c 160? Can a end loader be used on the auto 16? Share this post Link to post Share on other sites
Pullstart 70,695 #2 Posted August 8, 2023 They had a few changes in the names and nomenclature during some company sales and changes, but for all intensive purposes they were basically the same machines. Share this post Link to post Share on other sites
oliver2-44 11,628 #3 Posted August 8, 2023 Yes a front end loader can be used on an Auto 16. It will need a subframe for the loader 1 Share this post Link to post Share on other sites
Nathan W 5 #4 Posted August 8, 2023 Thanks I have 2 73 no name. The 14 and 16. 75 b100 and 82 gt1142. Briggs blew. Put a k341 on it. Only wh I have that's 8 speed. Original owner of the auto 16 and the 82 was my dad's I purchased the other too for parts and now I'm attached to all 4. Lol 1 Share this post Link to post Share on other sites
Nathan W 5 #5 Posted August 8, 2023 Since the 341 is on the 82. Will a m18 pancake motor fit on the auto 16 with hood modifications? I would like for this tractor to be used with an end loader. I got the motor off a Yazoo Share this post Link to post Share on other sites
ebinmaine 79,688 #6 Posted August 8, 2023 4 hours ago, Nathan W said: Since the 341 is on the 82. Will a m18 pancake motor fit on the auto 16 with hood modifications? I would like for this tractor to be used with an end loader. I got the motor off a Yazoo The forward angled steering tower and narrow hood are a challenge. Wheelhorse didn't have a Twin until the steering tower was straight vertical and the hoods were much larger. On the 1977 and older the Twin engine may have to set forward to allow proper alignment of the PTO Bell. Kohler twins can be made to fit in the older C Series if: 1. Relocate the battery. 2. Raise or modify the existing hood. Maybe both. If your intention is to build a front end loader tractor my inclination would be to use the 14 or 16 Kohler single cylinder. You don't need the extra HP of the big twin 18 and it'll create a lot of extra work. Share this post Link to post Share on other sites
Bill D 2,990 #7 Posted August 10, 2023 The M18 should fit fine in the GT1142. 1 Share this post Link to post Share on other sites
ebinmaine 79,688 #8 Posted August 10, 2023 1 minute ago, Bill D said: The M18 should fit fine in the GT1142. I was wondering about that too. I don't have anything newer to compare at. I was kind of thinking maybe take the K341 off the GT 1142 and put the M18 in there. Share this post Link to post Share on other sites
Bill D 2,990 #9 Posted August 10, 2023 51 minutes ago, ebinmaine said: I was wondering about that too. I don't have anything newer to compare at. I was kind of thinking maybe take the K341 off the GT 1142 and put the M18 in there. My thoughts exactly. 1 Share this post Link to post Share on other sites
Bill D 2,990 #10 Posted August 10, 2023 On 8/7/2023 at 11:41 PM, Nathan W said: Since the 341 is on the 82. Will a m18 pancake motor fit on the auto 16 with hood modifications? I would like for this tractor to be used with an end loader. I got the motor off a Yazoo Please note that most M18's don't have thrust bearings. Unless the engine is Wheel Horse spec it won't handle the side load from the PTO without failure. 1 Share this post Link to post Share on other sites
ebinmaine 79,688 #11 Posted August 10, 2023 3 minutes ago, Bill D said: Please note that most M18's don't have thrust bearings. Unless the engine is Wheel Horse spec it won't handle the side load from the PTO without failure. This is ok if ya use an electric PTO Share this post Link to post Share on other sites
Nathan W 5 #12 Posted August 10, 2023 Nice. I was looking the difference is the gas tank is under seat. Battery is located where 73 tank is. Thanks guys. Share this post Link to post Share on other sites
Bill D 2,990 #13 Posted August 10, 2023 25 minutes ago, ebinmaine said: This is ok if ya use an electric PTO True, and with in a loader application there shouldn't be a high shock load to the engine when the PTO is engaged. 1 Share this post Link to post Share on other sites
ebinmaine 79,688 #14 Posted August 10, 2023 37 minutes ago, Nathan W said: Nice. I was looking the difference is the gas tank is under seat. Battery is located where 73 tank is. Thanks guys. 78 up the fuel tank is under seat. Also the vertical steering tower stand. Offers lots of extra engine room. Share this post Link to post Share on other sites
Thor27 891 #15 Posted August 11, 2023 I'm not sure you would even need a pto for a loader, your just turning a pump so just a pulley would do. Share this post Link to post Share on other sites
oliver2-44 11,628 #16 Posted August 11, 2023 2 hours ago, Thor27 said: I'm not sure you would even need a pto for a loader, your just turning a pump so just a pulley would do. Kohler made stub shafts that bolt to the flywheel. Some of the tractors with inline engines like the Ford LGT 120 to 165. So a pump can be mounted there with a tensioner and will always be pumping and the relief valve working. If you put the pump on the PTO side and use it you can turn the pump off when your not using it. All of this also depends on what direction the pump turns. Share this post Link to post Share on other sites
